Hood release cable busted........
Old Oct 27, 2005 | 06:17 PM
quattrotto's Avatar
New Member
Default Hood release cable busted........
Any BTDT on opening the hood, finding a replacement cable and R&R? I think my princess is pissed at me for not driving her most of the summer......
Old Oct 28, 2005 | 06:48 AM
rally4s's Avatar
Default Re: Hood release cable busted........
If you are good with tools and have loong screw driver you can push on levers holding hood down.
If not head lights must go out or at list radiator grille and this will giv you access to this two levers/arms holding hood down.
Old Oct 28, 2005 | 05:35 PM
85urq's Avatar
Part avail at the dealer.
Very easy to install.
Leave the old unit in place until you are ready to replace it with a new one.
Its as easy as unscrewing the lever from the sidewall in the drivers side footwell, and using a bunch of tape to connect the old cable to the new one end-for-end, and fish it through the firewall.
In the front of the car where the radiator support is, you will see 5, or 6 white plastic clips, these are the cable guides, just take a nut driver (I don't remember what size) to loosen the cable from both of the hood release pin sockets.
The cable will slide right out of the guides.
The new cable goes right in, and you dont have to worry much about adjusting tension on the the sockets.
I'd remove the grille, and the headlight surrounds for the first few times you attemp to open the hood with the new cable, in case something wasn't right.
That way you can still open the hood....and try again.
If you located the hood pin release sockets, you can open the hood by moving the arm (which the cable runs through) to the direction of the drivers side of the car, and each one will pop the hood open.
Old Oct 28, 2005 | 06:00 PM
85urq's Avatar
Default Part # 811 823 531
From what I remember, it was less than 20 bucks....
Old Nov 5, 2005 | 12:34 PM
quattrotto's Avatar
New Member
Thanks!
nismofreak1208
Sep 18, 2016 06:56 PM
dwang
Audi Original "S" Cars
11
Feb 8, 2006 05:33 AM
StormChaser404
Jun 16, 2004 05:21 AM
tankman86
May 2, 2003 11:35 AM
pecar
Oct 21, 2002 09:08 PM
