Nav+ install question?
And if this is possible, next question is does Nav+ display text, so the screen would actually show the names of the songs on the MP3 CD/DVDs ?
Thanks in advance !
You want to make sure it puts the track information and maybe the mp3 text info on the screen when hooked up to the video outputs.
Now, the Nav+ does have video/audio inputs, but I'm not sure if it's PAL/NTSC or what, but I think most DVD players can switch between the two. So, I have not confirmed this but in theory, this should all work.
My best suggestion to you is to join the NavPlus Yahoo! group...
I figured I could burn MP3's on the DVD RWs, then put that into a glovebox mounted DVD player and play the music through that. Or is that not possible, are there only MP3 CDs ?
Having the screen say what's playing isn't necessarily the most important thing. It'd be nice. I know my friends Pioneer setup shows the names of the songs he is playing on his MP3 CDs so I figured if I could make Nav+ do that, it'd be that much cooler.
so prices went up a bit..)If you buy the NAV+ unit alone, you will only be able to use the the radio.
To get the GPS stuff working you will need the GPS attenna and wiring (+ $200). Plus you'll need the NAV+ CDs (+$200).
To get the CD changer working, you will need the CD changer and glove box (+$400).
To get the video, you'll need the TV Tuner module... (+$200). The TV Tuner will also give you the ability to feed the into the NAV+ system a PAL S-Video signal and a sound signal.
This will only give you the ability to do something with a PAL signal. Its up to you how to want to approach what you see on the display. Just think of it as a computer display. What can you make your computer screen do?
I have a source for the CDs probably. And for the whole install. I need to call him. I met this guy at the last VW/Audi meet down here and he had the install complete with Nav+ playing DVDs. So I guess I should get in contact with him ASAP and see what can be done, and if he can help with the install and finding the necessary parts.
