Tried out the Sunoco 100 octane unleaded last night - all I have to say is wow!
Old Jul 23, 2004 | 09:23 AM
Ming02's Avatar
Default Tried out the Sunoco 100 octane unleaded last night - all I have to say is wow!
Well - OK, I do have more to say. First off the price is a bit off-putting @ $4.99/gal. I already had 1/2 tank of 93 in the car and I added 4 gallons of the 100. So I figure I'm at least running 94.5 - 95 octane - maybe more, I didn't run the numbers. My car used to have a bit of a hesitation if I tried accelerating from about 2K up until just after 3K RPM. That hesitation is gone. Power delivery throughout the RPM range is very smooth and stronger. Sitting at a stoplight I almost wondered if the car was running - absolutely glass smooth idle. While the benefits of running a slightly higher octane than the 93 are many - the downside of it is - of course - the price. $20 only netted me 4 gallons. I have thought of using toluene instead, but it's price is quite high ($10/gal) unless I buy it in bulk (55 gal drum for $5.30/gal. maybe the higher octane of toluene would mean I'd use less than the 100 octane - but I think the price difference would be quite small.
Old Jul 23, 2004 | 09:26 AM
Audragon's Avatar
Junior Member
Wish I knew where to score 100 octane fuel.
Old Jul 23, 2004 | 09:41 AM
USP's Avatar
USP
are there any drawbacks to using such a high octane fuel (long term damage?)
Old Jul 23, 2004 | 09:49 AM
Ming02's Avatar
Default I would not think so, the computer will only adjust the engine within it's ability...
if a higher octane fuel is present (within reasonable limits) then I would think that it just would not be able to use it to it's full potential. I would think more damage would be done to your engine because of pinging and other issues due to insufficient octane. The only thing I would be worried about would be how the fuel is made unleaded - does it have the same chemicals that the standard unleaded fuel does or is it something different that could hurt some parts of the car. I just don't know. But I figured I would give it a try for a little bit - I didn't think that it would hurt.
Old Jul 23, 2004 | 09:50 AM
BriCK's Avatar
New Member
Default I think I found posts here about people using toluene from hardware stores for much cheaper.
That's the first I ever even heard of using toluene, though, so I'm no expert.
Old Jul 23, 2004 | 09:53 AM
Tsle's Avatar
No, as long as you make sure it's unleaded- Most 100 octane is leaded, which will kill your catalyst
Old Jul 23, 2004 | 10:30 AM
EROCK1500's Avatar
Junior Member
The local Sunoco in Brick, NJ has 100 octane. Never thought about buying it though.
Old Jul 23, 2004 | 10:36 AM
markbradford's Avatar
Rest In Peace
Most 100 in UNleaded. Anything higher than 105 is leaded
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 23, 2004 | 10:37 AM
Rest In Peace
Pretty much everywhere here (Chicago)
Old Jul 23, 2004 | 10:38 AM
Rest In Peace
Not really cheaper. It's $7-8 a gallon and 114 octane. Math is fun! =)
