Question regarding Peeps w/ lowered Suspension (Beyond OEM Sport) in the Snow Belt...
Just a concern of mine, the 1" or so lower clearance on the underbelly doesn't bother me as much as the above...
Any thoughts or input would be great...TIA.
I've never had a problem with the wheel wells getting clogged. I think it all boils down to what you expect from your car in drivability.
Hugh
Snow in the wheel well has never been an issue, but ice build up on the inside of crappy steel rims has been an issue since the balance goes out of whack. You end up having to wait till it melts, or see if you can reach under the car and hit the ice off with a stick.
Hugh
