rear wheel vs front wheel
Old Mar 12, 2005 | 05:26 PM
AndrewJM's Avatar
Member
Default rear wheel vs front wheel
what are the advantages/disadvantages of front wheel vs rear wheel drive?
i have the a4 front wheel, and im wondering why audi chooses front wheel instead of rear...
Old Mar 12, 2005 | 05:38 PM
ScottJ's Avatar
Default Depends on what you're intended application is.
For all-out handling separating steering duties from powering duties is best. See every major race car design for proof.
As much as I harp on its handling trade-offs in less than ideal traction conditions FWD has an advantage as understeer is easier to rein in than oversteer when you go over the edge.
Quatto with its abailty apportion torque front to rear and side to side all at once gives up a litte to RWD in the understeer dept. However, you cannot argue with its success on the track. It was so good it was banned in touring car.
Old Mar 12, 2005 | 05:40 PM
AndrewJM's Avatar
Member
Default what about having front wheel with a chip?
I have front wheel, and I want to get the apr stage 1 chip. would my front wheel car skid more with the extra power?
Old Mar 12, 2005 | 05:42 PM
ScottJ's Avatar
Default As for why Audi chooses it...
Front Track is essentially half the Quattro system.
Basic economics.
Economical assembly is why most FWD cars exist.
Old Mar 12, 2005 | 05:45 PM
ScottJ's Avatar
Default I don't know. When the fronts do all the duty
it's easier for the turning and powering forces to exceed the adhesion limits of the tires.
But there's probably enough buffer in there that a chip won't exceed.
You could also always increase the size of the performance envelope (raise the total adhesion limit) with a tire upgrade.
Old Mar 12, 2005 | 06:42 PM
Sharm's Avatar
Default FWD is easier to handle for average driver
It's hard to get into trouble with an FWD due to the understeer - but harder to control once you do.
RWD, easier for an average driver to skid, but if you know how to drive it you can control it better.
Big disadvantage with FWD is torque steer.
but it's better e.g in snow than RWD is
Essentially, for the great mass of drivers FWD understeer make their cars a bit safer.
Old Mar 12, 2005 | 06:58 PM
ScottJ's Avatar
Default I consider it a cop-out.
People should learn to <i>drive</i> rather than just motor about moving the wheel in the vauge direction they want to go.
Sadly, true drivers are the minority so FWD is the norm.
Old Mar 12, 2005 | 07:33 PM
AggregatVier's Avatar
Default Skid? The wheels will chirp/break-loose because of the torque increase.
I'm running just ~200HP and ~230 Torque and on cold mornings I have to be careful not to accellerate too quickly. (I've got CVT)
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 12, 2005 | 07:50 PM
Sharm's Avatar
True - but lots of people freeze when they get into a skid - and then kill others.
Old Mar 12, 2005 | 08:08 PM
ScottJ's Avatar
Default Yep. Completely different rant of mine.
Far too easy to get a license in this country.
Roads packed with "drivers" who have no clue about skid control and other limit dynamics.
