Clay bar-Very impressed (longish)
Old Mar 13, 2005 | 07:24 PM
Sharm's Avatar
Default Clay bar-Very impressed (longish)
Just washed the car, dried and then used a clay bar (Clay Magic) on it before polishing and glossing.
Very impressed indeed with the Clay Bar. Never heard of it before I came to the US - but it was very easy to use, made the paint super smooth (it was a bit rough before that) and removed lots of blemishes from the clear coat. Topped up with Auto Glym Resin and Extra Gloss as i have lots left. Might switch to Klasse later on (found it for $55 for 2 33oz of all in one and extra gloss)
On the same note - also used Armor-All fabric/carpet shampoo on the headliner and carpets - it created lots of froth and I'm not sure whether i got it all out of the headliner - but the resulting cleanliness was superb. I was really impressed and it's cheap too.
Just thought I'd let you know - if you haven't tried Claying i can recommend it. Thanks to those on the board who recommended it to me.
Cheers.
Old Mar 13, 2005 | 07:35 PM
chelskiSW6's Avatar
Junior Member
Default nice, im gonna do this to my car tomorrow...
how long did it take you to finish?
Old Mar 13, 2005 | 07:36 PM
nynyvtecjstkickdinyo's Avatar
Member
Glad you liked it....clay bar is a religious experience. a must 1x to 2x per year
Old Mar 13, 2005 | 07:37 PM
Member
should do whole car in hour or less
Old Mar 13, 2005 | 07:46 PM
Sharm's Avatar
Default Thanks. - Took about 45 mins to Clay
Just ran it over several times - and you feel it getting smooth.
It's a pretty easy process - just don;t try and do too large areas at a time - your lubricant will dry off.
FYI - Be careful up against the black vinyl and other bits - the bar will pick it up and go black so take care around those areas.
Also, for restricted areas - spraying the bar with lubricant works well also so you don;t get spray all over the place.
It works really well on glass - but I did the glass after the paint.
good luck.
After you do your first panel - run your finger over it and then another panel that you have washed but not clayed. you'll immediately notice the difference.
Old Mar 13, 2005 | 07:47 PM
Sharm's Avatar
Thanks. Yup, I have the zeal of the convert.
Old Mar 14, 2005 | 05:16 AM
Matt Devo's Avatar
Default better way to tell the diff is to use a plastic baggie
really lets you feel how smooth (or not) your paint is.
SJGQ5
Q5/SQ5 MKI (8R) Discussion
Aug 11, 2022 06:51 AM
PainDOC
17
Nov 1, 2018 06:00 PM
NorthValley
Apr 5, 2016 06:38 AM
Tom Kenney
Auto Detailing Discussion
Dec 8, 2015 05:53 AM
PainDOC
Sep 26, 2015 07:32 AM
