Paging EddieMan or other LED city light users
Old Mar 14, 2005 | 05:25 AM
Matt Devo's Avatar
Default Paging EddieMan or other LED city light users
I have the hyperwhite 4-element LEDs from myroadster.net. One of the elements in one of my LEDs went out the other night, and caused the other 3 to start flashing on and off. LED went bad? I thoguht they were supposed to have a longer life than halogens. I don't think it has to do with the fact that I'm running w/o LE's...
thoughts?
Old Mar 14, 2005 | 05:31 AM
A4Jared's Avatar
Member
it's probably just a manufacturing defect
Old Mar 14, 2005 | 05:34 AM
Turbosport's Avatar
AudiWorld Expert
Default hey man, I'm glad I caught you!
your shop just called...your ECU blew and needs to be replaced...oh, and your warrenty is now void ;-D
Old Mar 14, 2005 | 05:39 AM
A4Jared's Avatar
Member
Default ahhhhhhhhhh
here's the coincidence, I just called them llike twenty minutes ago. Apparently the guy doing the install is on some errand or "personal business". Should be done in "a few hours"
Old Mar 14, 2005 | 05:46 AM
Turbosport's Avatar
AudiWorld Expert
Default lol
hey man, I'm sorry but I had to do it...'specially after our conversation last night...best of luck with the install, and can't wait to hear your impressions :-D
Old Mar 14, 2005 | 06:21 AM
821 dtw (Greg)'s Avatar
Senior Member
no LEs = flashing
Old Mar 14, 2005 | 06:24 AM
A4Jared's Avatar
Member
not for 194 size. I helped with the LED install, there was no flashing so we didn't put in the LEs
Old Mar 14, 2005 | 07:16 AM
Senior Member
Default ah.... Matt - I have my old 4-bulb LEDs if you'd like to try out another
if you can't easily get a replacement.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 14, 2005 | 08:28 AM
Eddie Man's Avatar
Default Here's my take...
Since you've discovered that the LEDs for your Halogen Ecodes, DON'T need LEs; meaning that the resistance for the LEDs is ABOVE the tolerence for a bulb-out ERR.
That tolerance NOW has changed in that one of the LED filements went out...And more than likely that resistance is now BELOW the tolerence.
Now you are in a condition that the Xenon Ecodes experience w/o LEs.
As for the Hyperwhite LED going bad, that is probably a defect.
Hope this explanation makes sense.
Old Mar 14, 2005 | 09:14 AM
s4wood's Avatar
AudiWorld Expert
LEDs need way less energy to run..as compared to HIDs/other existing lighting sources
