I need your help, real quick, re: rear bumper being replaced..
Old Mar 14, 2005 | 08:47 AM
Awadd9's Avatar
Junior Member
Default I need your help, real quick, re: rear bumper being replaced..
I have searched an found part numbers for those that have done the S4 rear bumper. I am sticking with stock. 2004 Audi A4 1.8T..
Black with non-painted lowers.
I have seen four things I will need to complete. Now these are for a B6 S4 rear bumper. I know the aluminum trim piece is different but how about the mounting hardware?
8E5-807-443-B-2ZZ (Aluminum Bumper Molding) - $163.93
8E0-898-193-A (Mounting Kit) - $17.23
N-903-484-03 (Mounting Nut) - $.92
N-910-311-01 (Pop Rivet) - $.33
Is this even required or can I re-use the current bolts and fasteners.
Thanks,
Andrew
Old Mar 14, 2005 | 09:17 AM
Awadd9's Avatar
Junior Member
Anyone???
Old Mar 14, 2005 | 09:19 AM
German Driver's Avatar
Default i think foo posted necessary pieces on AZ
along with prices. i should be purchasing an s4 bumper soon so i will be doing same search as you.
Old Mar 14, 2005 | 09:32 AM
Turbo_Whip!'s Avatar
Default Re: I need your help, real quick, re: rear bumper being replaced..
i dont think you need to buy new mounting hardware, but the aluminum piece is necessary!
hope this helps
Old Mar 14, 2005 | 10:04 AM
A4Rye's Avatar
Default you'll need the aluminum trim strip, as far as the mount kit, I didnt get billed for one when I had
mine done. You should be ok using the same mounting hardware.
Goin over to KTR thursday?
Old Mar 14, 2005 | 10:25 AM
Awadd9's Avatar
Junior Member
Yea I will head up there when you go up. I will see you then and thanks for the 411
Old Mar 14, 2005 | 10:42 AM
A4Rye's Avatar
Default I plan on leaving the city arround 1:45 or 2
so tha tshould put me at KTR arround 2:30-2:45 or so
Old Mar 14, 2005 | 11:16 AM
Default ETKA
<img src="http://itypical.com/scott/ETOSRearBumper2-vi.jpg">
<img src="http://itypical.com/scott/ETOSRearBumper1-vi.jpg">
<img src="http://itypical.com/scott/ETKARearBumper1-vi.jpg">
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 14, 2005 | 11:46 AM
Awadd9's Avatar
Junior Member
Default Re: ETKA
HUGE
Old Mar 14, 2005 | 12:20 PM
Cmmartin23
26
Aug 23, 2016 04:44 PM
Jan_PL_S6
12
Nov 27, 2015 07:27 AM
Wza
A6 (C7 Platform) Discussion
Sep 10, 2015 11:03 AM
S4intheOC
Sep 8, 2015 12:12 AM
