k...I've searched...but couldn't find a definitive answer...
Old Mar 15, 2005 | 04:05 PM
Hanwei's Avatar
Junior Member
Default k...I've searched...but couldn't find a definitive answer...
As many of you know I've put my 19"s on recently... and haven't hit ANY potholes... but since I've put them on (they came balanced with hubcentric rings) when I'm on the highway... at about 70mph I start to feel a very slight vibration... all over the car...not just the steering wheel... (if I put my hand on the passenger seat I can feel it... if I put my hand on the shift **** I can feel it...) and the faster the speeds get the more intense the vibration gets. I can't go faster than 85 without it feeling uncomfortable.
Since the vibration has been there at high speeds ever since I put on the rims... could one or more of them be balanced wrong? It's not alignment right?
I've retightened all the lug nuts (using oem lugs)... not sure what else to do...
Old Mar 15, 2005 | 04:08 PM
atito's Avatar
New Member
Default be careful
tighten you lugs correctly, i believe it could case brake damage.
is your car lowered? if so you should realign your car.
Old Mar 15, 2005 | 04:11 PM
a02a418ts's Avatar
New Member
Default One of your wheels is off balance.
Sometimes in the winter when one wheel collects a lot more snow than the others I get the same feel because its causing that wheel to be off balance. So I bet that is your problem.
Old Mar 15, 2005 | 04:43 PM
cyber_m0nkey's Avatar
New Member
Get the alignment checked!
Old Mar 15, 2005 | 04:45 PM
Vonbimmer's Avatar
New Member
I had a similar issue with P-Zero Nero M+S. Defective tires with radial runout.
Old Mar 15, 2005 | 05:17 PM
Hanwei's Avatar
Junior Member
what does radial runout mean?
Old Mar 15, 2005 | 05:18 PM
Hanwei's Avatar
Junior Member
Default If the alignment is off it will just cause the car to pull to one side or the other...not
cause vibration...am I wrong?
Old Mar 15, 2005 | 05:19 PM
Hanwei's Avatar
Junior Member
Not lowered... and lugs tightened opposite each other with torque wrench @90lbs
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 15, 2005 | 05:26 PM
Projekt 8E's Avatar
AudiWorld Expert
Default My HRE's as well as A4NCAR's will do that in the rain to the point where I will have to pull over
and then I start driving again and it's all better. it's fvcking lame.
Old Mar 15, 2005 | 05:31 PM
user 46462's Avatar
Banned
Are you using the lugs that are meant for the 19s?
