Anybody in CT can help replacing O2 sensor?
Old Feb 18, 2006 | 05:08 PM
camikazi2k's Avatar
Default Anybody in CT can help replacing O2 sensor?
Anybody welling to help replace my O2 sensor,
am reading just dont want to screw anything up. and do i need any special tools?
i live in waterbury, welling to drive anywhere
Old Feb 18, 2006 | 06:23 PM
EddieDellz's Avatar
engine?
Old Feb 18, 2006 | 06:54 PM
camikazi2k's Avatar
Default yup the engine side
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
Old Feb 19, 2006 | 04:08 AM
EddieDellz's Avatar
what engine do you have
Old Feb 19, 2006 | 07:05 AM
camikazi2k's Avatar
Boost leak everybody saying, anybody know how to test?
Old Feb 20, 2006 | 08:17 AM
Rocky-in-Connecticut's Avatar
Default you're a little far away but
if you can get to the Stamford area I have Vag Com and a "gnarly set of tools." (in my best Jeff Spicoli voice). It may not be o2 sensors but you do need Vag Com to check some things to really do proper diag.
Old Feb 20, 2006 | 03:23 PM
camikazi2k's Avatar
2.7L
Old Feb 20, 2006 | 03:33 PM
camikazi2k's Avatar
Default i DID RUN vAG-cOM ON IT HERE IS THE LIST
I will post the list when i get home, do you know how to check for leak? am welling to drive to stamford am off all week on vacation.
let me know
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 21, 2006 | 07:11 AM
camikazi2k's Avatar
Default List from Auto Zone after cleaning
ok here is the new list i got from Auto Zone, i took the ABS module off and sent it out for repair, should be back by next week some time
I cleaned the MAF sensor with cleaner from Advance Auto.
what else do i have to do?
Codes
DTD (Codes)
P1606
Manafcurer Contrl,
Auxiliary Inputs
Auxiliary Outputs
P0102
MAF or VAF
Circuit Low Input
P1113
Manfacurer Contrl.
Fuel Air Metering
bballfreak
9
Apr 14, 2019 06:59 PM
brandonb93
A4 (B7 Platform) Discussion
12
Dec 4, 2018 01:16 PM
jamile222
Sep 29, 2015 11:22 AM
dgw124
Sep 27, 2015 07:26 PM
Ryan Mccormick
New Member Welcome Area
Sep 26, 2015 09:11 PM
