So...post all the BS I went through with the coolant etc etc.. (edited)
Old Aug 31, 2006 | 05:22 AM
LI-S4's Avatar
Default So...post all the BS I went through with the coolant etc etc.. (edited)
I knocked nearly a full second off my FATS time running a more conservative software and pump gas..
I was at close to six seconds (5.7) on k03's with APR 100 oct software and race gas (one 4.66 which was an anomoly never to be repeated, must have been going downhill over the 'causeway).
Pulled three consistent 5.00x on k04's with 93 software.
Mission accomplished. Next up...fueling...looking to knock another second off that time. I want low 4 seconds. Considering Revolver cams...and EPL custom tuning...(gotta do some more V1's and RS4 mesh..maybe sell a nut or two)
On a lighter note...Who were the three musketeers in the A6 waiving me on out at the beach? One minute you were in front of me...byt ten cars and next minute you were bhind me by twenty!!
Ocean Pky rules...with the exception of the bugs..it was like Jim Carey on the bike in Me, Myself & Irene..thwap, thwap thwap, thwap..my front end is a mess..can't see a thing out my windshield.
That is all, thanks for reading.
Old Aug 31, 2006 | 05:36 AM
ECD212 Reborn's Avatar
Good job Lisa! Glad the car is coming along nicely.
Old Aug 31, 2006 | 05:45 AM
2PUTT's Avatar
great news!!
Old Aug 31, 2006 | 06:00 AM
LI-S4's Avatar
Default GIAC or APR?
GIAC will easily pull mid to low 4's.
APR should be at 5.0x - 5.1x...so I am on target.
At this point, I refuse to defect from APR, The extra .x seconds isn't worth the change.
And, I'll bet after tonight, with all that junk out of the trunk, less fuel and lower IAT's (the **** in the trunk and the 3/4 tank is estimated at nearly 150 lbs) I should easily break 5 seconds... a 4.8x would be nice.
Old Aug 31, 2006 | 06:24 AM
BLKPERL's Avatar
Default Where do you do your FATS runs?
I have a hard time finding a road that is level & straight where you can do a 3rd gear pull to redline. The A4's use a CAPS system
Old Aug 31, 2006 | 06:42 AM
LI-S4's Avatar
noice...
Old Aug 31, 2006 | 06:54 AM
LI-S4's Avatar
Default You're kidding??? How long are you living on Long Island??
<center><img src="http://images8.fotki.com/v137/photos/4/43687/1683699/36_1_61-vi.gif"></center>
Does this look familiar?? Straight and flat...
<img src="http://images18.fotki.com/v342/photos/4/43687/1652609/Pic002-vi.jpg">
Ocean Pky out in the beach... What is CAPS??
Old Aug 31, 2006 | 07:15 AM
BLKPERL's Avatar
Default CAPS is A4 version of S4 FATS
Aren't there a lot of cops out on Ocean pkwy?
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 31, 2006 | 07:43 AM
LI-S4's Avatar
Default Not really...
I typically do a recon pass each way, keeping the V1 on, and letting the temps stabilize.. There was a six degree drop in ambient as you go over the bridge. It helps to have someone with you with a radio.. Bones came out to meet me, but got there after I had finished..
<img src="http://images17.fotki.com/v304/photos/4/43687/1652609/Pic004-vi.jpg">
If you don't like the beach, you can use Sunrise out east..around Medford...it's wide open and you can see for a good distance.
What does CAPS stand for, and how do you do it? FATS is a third gear pull encompassing 4200 - 6500 RPM at WOT. About 50/60 to 90mph. Of course I have never gone that fast... The VAG-COM data is dropped into any of a couple of excel sheets floating round and the exact time is calc'd. Since VAG-COM has a fairly low sampling rate, RPM's below 4200 and above 6500 need to be interpolated to get the time stamps exactly at the right RPM..
Old Aug 31, 2006 | 07:48 AM
BLKPERL's Avatar
Default Similar
<ul><li><a href="http://www.modifieda4.com/web/caps/b518-new.html">http://www.modifieda4.com/web/caps/b518-new.html</a</li></ul>
