Slow today. Worst repair mistake you ever did on a vehicle? mine is...
Old Dec 14, 2007 | 11:34 AM
KillA6's Avatar
Default Slow today. Worst repair mistake you ever did on a vehicle? mine is...
I was changing out a timing chain plastic guard on my pick up. I was doing it the hard way taking as little off as possible. There were 2 screws holding in the old guard. I ripped a t shirt shoved it down near crank gear so I wouldn't drop the bolts down. saved me a few times. Everything went well.
My sister shows up at my house and chews my ear off for 45min about nothing. I go back button everthing up. turn it over. starts to go then stops. i try again and thats when I realized.
i left the shirt in there. yup. valve kissed the piston b/c the shirt wrapped around the crank sprocket and jumped timming. I had to do a basic total rebuild after. valves and pistons were fine though. Still in process.
Old Dec 14, 2007 | 11:52 AM
iconoclast's Avatar
AudiWorld Expert
Default in general: working on a volvo bertoni...
<center><img src="http://media.buysell.com/userphotos/calgary/avus/20071006/4011731_2.jpg"></center><p>the biggest mistake was her buying it, and me touching it.
Old Dec 14, 2007 | 01:08 PM
Three-twelve's Avatar
id go with Clear corner mod and RS4 lower mesh on my S4 bumper. love the look but just isnt perfect
Old Dec 14, 2007 | 01:59 PM
phg60's Avatar
Default Installing Hella SuperTone horns on the S4
Replaced the stock horns, Now I can't get the front bumper to sit right (Ends stick out, Can't 'catch" the bracket)
Old Dec 14, 2007 | 04:40 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Did something similar while doing a head gasket on my 83 Jetta. I'm sure you can see where is going
4 rags at the beginning, 3 rags when I was done. Fortunately I discovered the mistake before I turned the key. I ended up pulling the rag out through the spark plug hole in little tiny pieces. Took me half an hour.
Old Dec 14, 2007 | 05:54 PM
SFexBOY's Avatar
Member
Default several months ago when I was doing my 2nd timing belt install, I neglected to tighten the 4 bolts..
<center><img src="https://www.audiworld.com/tech/pics/eng35-ac_tensioner1.jpg"></center><p>
that hold the accessory belts (pictured on the upper right hand corner of the pic above), and didn't understand why my car was making some weird noises. Luckily when i brought it to Quattrohaus for them to diagnose the sound, they somehow figured out that I forgot to tighten this. They saved me from disaster.
Old Dec 14, 2007 | 06:22 PM
5speed6  v.2's Avatar
Member
Default funny you should mention that car...
.well funny now anyway.
Many, many moons ago I agreed to install an in-car cell phone and hands free kit for my friends boss.
No problem I thought...easy install, cash job.
Yeah right!!
The leather trim panels on the pillars, and the carpeting was glued down to the metal in those cars.
What a nightmare!!!
Oh, and it's Bertone,with an "e" at the end.
Old Dec 14, 2007 | 07:15 PM
iconoclast's Avatar
AudiWorld Expert
Default lol. that car is a piece of crap.
thanks for the heads up on the spelling, its been almost 11yrs since ive seen that car...
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 15, 2007 | 04:49 AM
quattro_blue's Avatar
Default Installed camshaft sprocket on my 1.8T wrong way.
On the other side of that sprocket there is also mark. Engine was working like diesel, had to buy new sprocket b/c old one almost chipped tooth (inside), redo TB, everything OK.
Old Dec 15, 2007 | 06:37 AM
LI-S4's Avatar
Dropped the trans on my TR8 and couldn't get it back in
