In case you're wondering what 11 year old DOT 3 hydraulic fluid looks like...
Old Oct 15, 2006 | 05:40 AM
Jimax's Avatar
Default In case you're wondering what 11 year old DOT 3 hydraulic fluid looks like...
I'm now a believer in flushing brake and clutch fluids regularly. Julia and Rob came over yesterday and we did brake fluid flushes (well, we never got to Julia's brakes, just spark plugs). Rob did his allroad and I did my Civic.
Here is what came out of the clutch. I am pretty sure this is the original fluid as were the brakes. You know what brake fluid looks like, it's clear with a light tan hue to it. You can't even see through this!
Anybody know where the clutch bleeder valve is on a B6 A4 3.0? I'm going to do that next.
<img src="http://i45.photobucket.com/albums/f95/eljimax/IMG_0928.jpg">
Old Oct 15, 2006 | 05:46 AM
EDness's Avatar
Default damn!
i flushed my tercel twice since i got it. I'm about to do it again once i get the car back on the road...it needs a new tb tensioner.
Old Oct 15, 2006 | 05:51 AM
Jimax's Avatar
Yeah, I'd been meaning to flush brakes/clutch since I bought the car but never got around to it
Old Oct 15, 2006 | 08:18 AM
BSK's Avatar
BSK
I do my brakes/clutch once per year
Old Oct 15, 2006 | 09:12 AM
Jimax's Avatar
How do you do the clutch on the Audi?
Old Oct 15, 2006 | 10:43 AM
RKA's Avatar
RKA
AudiWorld Uber User
Default You're brave...I wouldn't touch an 11 year old car with original fluid.
Too much crap accumulates in those lines, and when you flush, it moves around. Some of it may harm the master cylinder, some of it may eventually harm the calipers, and it may lodge inside the bleeder valves (if you don't strip them trying to break them free).
At 11 years it's time to use the motto..."if it ain't broke, leave it alone", because you stand a better chance of costing yourself more money by trying to be a meticulous car owner at that stage in the game.
I tried it on my 7 year old Honda...a bunch of crap spewed out of the bleeder...I was happy thinking I was doing a good thing...until the fluid would no longer come out. At that point I buttoned everything up, tested the brakes fearing the worst, and when I discovered they worked, I stopped messing around with the brakes and considered myself lucky.
Old Oct 15, 2006 | 11:00 AM
Jimax's Avatar
Default I was lucky, fluid and debris kept flowing out
Every push of the brake pedal yielded a lot of fluid coming out of the bleeder valve. BTW, the bleeder valves were tight, but a little muscle behind them and they loosened right up.
And honestly, if debris messes up the calipers or the master cylinder, that's fine. It gives me an excuse to upgrade. Integra master cylinder, calipers, rotors, fit right on to my car.
The reason why I flushed though was A) the brake pedal was going down way too far before it would grab. I'm sure 178K miles of fluid has moisture and air in the lines. Second, the clutch was totally empty and needed to be refilled anyway. Once we refilled it (to start the flush), the fliud immediately turned black (from worn out seals, maybe?). We went ahead and kept flushing until the fluid came out clear.
I probably will cost myself money, but if I don't get the proper maintenance done, I'll lose sleep at night. The thought ALWAYS pops in my head that what if someone borrows the car and something goes out on them while they're driving, I'd never forgive myself. So, I try to stay on top of all maintenance items to ensure reliability.
Old Oct 15, 2006 | 11:27 AM
EDness's Avatar
you did the rear drums too right?
 Michael S. Palmer
Old Oct 15, 2006 | 11:36 AM
Jimax's Avatar
Yup, all four corners
Old Oct 15, 2006 | 01:00 PM
BSK's Avatar
BSK
Default on the b5 you go over the drivers side axle and find the nipple that sits slightly underneath the
brake reservoir and bleed from there
