x-post... 4000 project update...
Old Oct 16, 2006 | 05:28 AM
Jretal's Avatar
Default x-post... 4000 project update...
I figured since I was done with all my take home tests and didn't have class to prep for this week (even grad students get a fall break, ain't that nice?) I'd spend some QT with the 'ol 4000 that's been taking up my garage for the past 2 months.
Started prepping the car so I could get to the firewall to do wiring, and what not for the 034 ECU
Started off pulling out the pesky Evap core... car is getting stripped of its A/C, so no need to have it sitting there. Here it is pulled:
<img src="http://pictureposter.audiworld.com/21175/img_1020.jpg">
Since I couldn't easily get to the screws on the back side of the evap core cuz I didn't drop the housing down (I didn't feel like tearing out the entire hvac box to accomplish this) I just ended up breaking it out I then trimmed the tabs off it. I'm planning on mounting up a piece of sheet metal or aluminum to mount the Ib ecu... gotta figure out which I can get easier and get it done.
evap core pulled:
<img src="http://pictureposter.audiworld.com/21175/img_1021.jpg">
I then started pulling the battery cable through the car (after removing the rear seats and front pass seat) and into the trunk for the relocation
<img src="http://pictureposter.audiworld.com/21175/img_1022.jpg">
Here's what the battery box will look like in the trunk...
<img src="http://pictureposter.audiworld.com/21175/img_1039.jpg">
I'm not too happy with the layout and how this box works in all honesty, but I'll make due with it I guess. I'm very disappointed with how they want you to mount the box and clip the battery in so it doesn't shift... and being that the trunk in the 4000 is far from flat (at least where i'm planning on putting it) it makes life a lot more difficult. I have some ideas of strapping that I'm gonna put under the box and bolt the box to it that way, but we'll see what I can come up with. The hardware store was closed by the time I started really thinking about this, so I decided to leave that for another day.
and here's the inside of the car, ready for me to start doing some wiring
<img src="http://pictureposter.audiworld.com/21175/img_1026.jpg">
While I had the interior torn apart, I figured I'd check on my heater core. I had a hunch that it was shot over the winter when I was using the car cuz I was getting that tell tale sweet smell in the air... and sure enough, my hunch was unfortunately correct Oh well, tack that onto the pile of parts I need to order.
<img src="http://pictureposter.audiworld.com/21175/img_1032.jpg">
From there, I positioned my 200 amp breaker on the firewall. I liked Javad's idea (034 Motorsports), so I figured I'd go with it as well... makes a good hub to mount up all the interior stuff as well as a jumping block if I ever have an issue w/ a dead battery and don't feel like digging into the trunk.
<img src="http://pictureposter.audiworld.com/21175/img_1037.jpg">
and here it is with the battery cable from the trunk wired to it:
<img src="http://pictureposter.audiworld.com/21175/img_1043.jpg">
I'm gonna solder on the terminal end after I get the battery box fully installed. I want to make sure I leave myself as much slack as I need for the trunk. There's a good 5 feet of excess in the engine bay right now, so that'll make a perfect new wire to go to the starter motor once I get that all figured out
So that's about it for the weekend. I kinda worked on the car when i felt like it... Had to enjoy a lil time on the beach for oct fest I got all week off from class though, so I'll be working pretty diligently on this all week.
For this week, the first goal is to get the battery box fully installed. From there, I'll start working on getting the ECU wired the rest of the way in and get all the necessary wires run. Also, I need to find a switched power feed to give power to the ECU...
That's it from me... hope ya enjoyed the show!
Old Oct 16, 2006 | 05:57 AM
4Rings::G2 boosted::'s Avatar
Banned
I'm getting tired just thinking how much work it's gonna take to put this back together
Old Oct 16, 2006 | 06:12 AM
85-4kq-girl's Avatar
But it will be worth it!
Old Oct 16, 2006 | 06:58 AM
Jretal's Avatar
Default lol... you and me both...
and I'm crying as well thinking about what else I need to drop $$ on... haha.
Thankfully I was able to pull a slight profit on the parts car and turbo, so that will at least offset a LITTLE bit of the funds... like allow me to buy the stage 2 spec clutch from 034. Jury is still out whether I want to lighten my flywheel or not... not sure its worth the $75 at this point.
Old Oct 16, 2006 | 07:00 AM
Jretal's Avatar
Default you betchur a$$ it will be :-D
whenever I get bummed about the project, I just think about how much fun this car is going to be once I'm done... and all those concerns go away.
I have to admit though, I'm having a good time problem solving and figuring out work arounds for issues I run into... must be the engineer in me
Old Oct 16, 2006 | 03:05 PM
Roger @ CA's Avatar
Nice stuff... Did my battery relocation on the A4 last week... looks similar to yours.
Old Oct 21, 2006 | 10:24 AM
The Real Tinman's Avatar
New Member
Default Re: x-post... 4000 project update...
get movin' on that damn project, punk!
L8
Old Oct 23, 2006 | 07:55 AM
Jretal's Avatar
Default ha, sure thing benny...
almost have the battery box ready to accept the battery in the trunk... too bad I got class tonight...
I say christmas time it'll be ready to rip
 Pouria Savadkouei
 Michael S. Palmer
vwleadfoot
Audi Original "S" Cars
Dec 24, 2015 06:07 AM
rjdoc74
Q5/SQ5 MKI (8R) Discussion
18
Oct 10, 2015 05:47 AM
fixmya6
Oct 1, 2015 02:00 PM
jlbell
Sep 27, 2015 09:23 PM
blackjulia
Sep 27, 2015 09:37 AM
