Can the factory installed speed limiting chip (130mph) be removed?...
I'll add that the manual is a bit confusing because they then go on to describe how the limiter works and that normal operation resumes at 124mph. It's obviously assuming that you have H rated tires. They should probably add a statement that basically says "or 6 mph below your max allowable" or something like that.
