S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
coolant
Old Jul 11, 2004 | 12:47 PM
davyk3's Avatar
Member
Default coolant
my coolant goes below the minimum, what should I do? just refill myself with regular coolant or go to the dealer
Old Jul 11, 2004 | 12:50 PM
nbevins's Avatar
Member
Default Audi uses sort of special coolant.
Just take to dealer and ask them why a brand new car is loosing coolant!
Old Jul 11, 2004 | 01:00 PM
davyk3's Avatar
Member
that's what i was going to do, but i put in coolant just in case, what should i do????
Old Jul 11, 2004 | 01:06 PM
nbevins's Avatar
Member
Default As long as you matched colors (red with red coolant) you should be fine.
Just can't mix green with red. Your audi should have red.
I would wait for it to run down to the min. mark again and then take it in (maybe ask for a flush and refill back to OEM stuff). Any car, much less a new car, should not use (or loose) ANY coolant.
Old Jul 11, 2004 | 01:08 PM
nbevins's Avatar
Member
Default Also keep an eye on that coolant temp guage. Chance of overheating if system is loosing pressure.
Might just want to take it in and tell what happened?
Old Jul 11, 2004 | 01:43 PM
davyk3's Avatar
Member
crap, i mixed colors....
Old Jul 11, 2004 | 01:45 PM
Chris129's Avatar
Use G12 coolant from the dealer... they will hook you up.
Old Jul 11, 2004 | 01:46 PM
Chris129's Avatar
Yo, take it to the dealer... they need to drain and refill your coolant
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 11, 2004 | 01:55 PM
nbevins's Avatar
Member
2nd, I would take it straight to the dealer and explain what happened.
Old Jul 11, 2004 | 02:09 PM
davyk3's Avatar
Member
is it that critical, don't have time to go soon, cause i gotta drive somewhere
