S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Two small issues:
Old Jul 14, 2004 | 07:47 AM
Captain Sheetmetal's Avatar
Senior Member
Default Two small issues:
1) Something in my engine bay (I think) rattles. It is not the chain tensioner rattle (or whatever that noise really is). It happens when in gear and I accelerate through the 850rpm range and lasts only until about 1000rpm. It sounds like the harmonics of the engine are causing either a) a plastic piece to dance around, or b) *maybe* a part of the exhaust to do the same. Any one else heard this?
2) It is difficult to get my car into reverse and first gear. It has been this way since I picked up the car and is not improving. It is also not getting any worse and generally does not keep me from using either of those two gears, though sometimes it does take me 5-10 seconds to engage those gears. Again, does anybody else experience this? It does not improve after the car has warmed up.
Old Jul 14, 2004 | 07:48 AM
MachtigAvant (v3.0)'s Avatar
Elder Member
Default No SS right?
I'd take it in and get the tranny looked out. What's the build date on your car? Might need the TSB to be looked at. You can download it from my sig.
Old Jul 14, 2004 | 07:50 AM
HarnessedLunacy's Avatar
Default I think they can adjust the linkage to fix the shifting problem. . .
and maybe your manifold is loose (per TSB) causing noise from the engine bay?
I would definitely take it in and have it checked out. .
Good luck.
Old Jul 14, 2004 | 07:51 AM
dojo's Avatar
Default that's not normal, go see AOA or your local dealer.
sorry to hear about that.
Old Jul 14, 2004 | 07:54 AM
Senior Member
No SS. Built in May 2004...one of the last '04 models.
Old Jul 14, 2004 | 07:56 AM
Elder Member
Default Hmm, should not be the No reverse issue. I'd recommend you take it in and get it looked for sure...
and perhaps have them straighten up the linkage, that should do the trick.
Old Jul 14, 2004 | 08:09 AM
Pete @ Stratmosphere's Avatar
Former Vendor
Default How does the shift shaft stand in neutral...
is it straight up fore/aft, left/right? If so, it's time for a service appointment. -Pete, Strat
Old Jul 14, 2004 | 08:36 AM
Senior Member
Default It stands...um...erect.
It may be leaning slightly rearward, but it is very close to perpendicular, in both axes, to the wood trim panel that surrounds it.
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 14, 2004 | 08:46 AM
Orangeblood's Avatar
huh huh, he said erect and wood. huh huh, huh.
Old Jul 14, 2004 | 10:25 AM
jpc-S4's Avatar
Settle down, Beavis!
