S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Looking for a link to exact cable routing for radar hard wire.
Old Aug 14, 2004 | 07:23 PM
KentuckyS4's Avatar
Default Looking for a link to exact cable routing for radar hard wire.
I have searched and found a fair number of radar detector hard wire installs, and most just simply mention that they route the cable along the liner and the pillar, down to the fuse box. The head liner is pretty obvious, but I'm just wondering if anyone has a link to a post that shows exactly where to route the cable down the pillar. If I route it right against the windshield I end up down at the front of the dash and need to find a concealed way to get back to where the fuse panel is. Can I route the cable inbetween where the side and main pieces of the dash meet, or is there a better way? Also, once I get into the fuse panel, is there a "standard" fuse that everyone uses for this, or just basically use anything operates on switched power?
Thanks in advance for any help! I'm really looking forwared to concealing the cable for my Passport 8500 X50.
Old Aug 14, 2004 | 07:37 PM
ivansis's Avatar
Default I used CCard and was able to insert cable between A-pillar and dash to the fuse box...
however don't know which fuse to use either (see my post below), but routing the wire was pretty easy.
Old Aug 14, 2004 | 08:38 PM
dent2003's Avatar
Default I just hardwired my 8500 X50 today....
and I too ran the wire along the windshield across the top, down the A-pillar, around the sharp little corner, back thru the small crack and down into the fuse box... I used simply a credit card and a small flat blade screwdriver being careful not to puncture the wire's cover.. tap into fuse 36, the wipers, as it is switched power... Go to radio shack, buy a $4 std. phone jack w/ 8" of wire attached, and you don't have to spend the 10+ from escort.. I'll post part numbers tomorrow.. wire the green on the plug from radio shack to the hot, and yellow is ground, in which I screwed the y-clip into one of the two screws holding the map light assembly up... I also ran an inline fuse adapter (also from radio shack) w/ a 2 amp fast burning fuse for protection.
Old Aug 15, 2004 | 06:16 AM
KentuckyS4's Avatar
Default Thanks for the responses! Escort sent me the hardwire cable free...
...along with free shipping, but the phone cable tip is still nice because now I can make a second hardwire cable for my wife's vehicle. Thanks!
Old Aug 15, 2004 | 09:39 AM
Inphidel's Avatar
Junior Member
Default I suggest disabling X band, walgreens/hy-vee will drive you nuts.
Turn X band back on if you go to IA, though.
Old Aug 15, 2004 | 06:11 PM
©odeWhore's Avatar
Default Check my sig
There are a few very detailed posts, with people actually taking A-pillar covers off 'n stuff...
Old Aug 15, 2004 | 07:00 PM
dent2003's Avatar
Eric- could I check out/hear the Miltek sometime? Res or Non?
Old Aug 15, 2004 | 08:02 PM
Inphidel's Avatar
Junior Member
Default Sure!! It would be my pleasure!
I have the Milltek resonated, and I am pretty happy with it. Be happy to show it to you. I also have a vag-com if you want to do those mods.
Shoot me an email and we can get together sometime.
 Pouria Savadkouei
 Michael S. Palmer
Lord Vader
May 13, 2013 06:07 PM
2003a4MT6
May 22, 2006 04:24 AM
omar1956
Jan 23, 2005 09:28 PM
brad21
Nov 11, 2001 04:00 PM
brad21
Nov 8, 2001 06:37 AM
