S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
DBW update: 100% unequivocally cured.
Old Aug 16, 2004 | 08:15 PM
Captain Sheetmetal's Avatar
Senior Member
Default DBW update: 100% unequivocally cured.
As I posted this morning, my little gift from FedEx showed up; a simple build-it-yourself adjustable relay. I didn't know how to build a relay, but I followed the directions and about 30 soldering connections later, I had my relay!
Anyway, this evening I set about wiring it up to my car (see link in my sig for more info) and with the exception of one little hiccup, it all works exactly how I had hoped. The little hiccup was that I thought I could power the relay with a 9 volt battery even though the documentation stated clearly that it needed 12 volts to operate. The package was right. Once I wired up another 9 volt battery in series though, I was good to go.
Anyway...a HUGE change has taken place. Full throttle now immediately equals full throttle. No throttle now immediately equals no throttle--violently so. I accelerated up to about 5500rpm and "side-stepped" the gas pedal (took my foot off quickly) and was absolutely THROWN into my seatbelt. If I hadn't been wearing it, I would have honked the horn with my face--I'm not kidding. The same holds true you when I apply the throttle--instant, violent response.
A side benefit is that shifting becomes much more intuitive, now that the car doesn't flip between two different throttle maps with each application of the clutch pedal.
The only downside is that the relay on 18 volts sounds like a cricket on speed. I have to find a little less industrial version.
If anybody is interested shoot me an email or post questions and I'll tell y'all what to do!
PS--AvramD...you got rid of your S4 a week early. I am convinced you would have reconsidered your decision if you tried this.
Old Aug 16, 2004 | 08:53 PM
S4Tuned's Avatar
AudiWorld Expert
Whoa, keep us updated. I want that raw feeling.
S4Tuned's Avatar
AudiWorld Expert
Actually, can we meet up sometime so you can show me in person what you did?
Old Aug 16, 2004 | 09:01 PM
Senior Member
Default Sure.
I need to straighten everything out a little bit. I have no on/off switch yet and the whole apparatus is just sitting in the storage thing under the armrest. Functionally, it's perfect though, so any time you want to meet, I'm game. Evenings are best; send me an email.
Old Aug 16, 2004 | 09:09 PM
B6S4play's Avatar
New Member
Default Re: Sure.
couldnt you just run 12v power of the car?
Old Aug 16, 2004 | 09:13 PM
S4Tuned's Avatar
AudiWorld Expert
Awesome. I will send you an email shortly.
Old Aug 16, 2004 | 09:15 PM
Senior Member
Default Yes.
I didn't want to deal with that tonight though. That will be the permanent solution.
Old Aug 16, 2004 | 10:50 PM
CarbonFibre's Avatar
Default Hmm...
So what exactly did you do? I don't really understand what this relay does.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 17, 2004 | 02:49 AM
JDBlueAudiS4's Avatar
Default Well what I can tell you is....
The DBW system has 3 problems.
1) The Throttle Map
2) the selanoid and other hardware that doesnt read 100%
3) The way the two systems interact.
Chips fix the throttle map. This relay fixes a little of 2 & 3. What you have to do is slightly over compinsate and then you only need to correct one system or the other.
Old Aug 17, 2004 | 03:57 AM
No More B5 S4's Avatar
Elder Member
Default This is/was a problem on the M and T Box B5 S4s. I have a very simple fix...
<center><img src="http://pictureposter.audiworld.com/41217/throttlemod1.jpg"></center><p><ul><li><a href="https://forums.audiworld.com/s4/msgs/935010.phtml">Don't know if it's the same/similar problem for your B6s.</a></li></ul>
