S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
I need part number for the following items!!!!!
Old Aug 18, 2004 | 04:37 AM
mindtrip's Avatar
Default I need part number for the following items!!!!!
Stock Sedan Shift ***
Metal clips that hold consol around shifter in place.
During my adjustment of the SS I lost 2 of the clips and the aluminum, trim is a little loose. and I cracked some of the plastic clips off the shift *** and it does not stay in place well. If any one can help me out I would appreciate it.
Old Aug 18, 2004 | 04:45 AM
JDBlueAudiS4's Avatar
Default The OEM shift **** costs more then buying a **** and boot from TyCoOn....
plus the alcantera boots are sweet. Mine was 100 shipped for black alcantera with a air leather shifter.
Old Aug 18, 2004 | 04:52 AM
MachtigAvant (v3.0)'s Avatar
Elder Member
Default Hmm...the clips might still be in the shifter console actually, check to see if they are still in...
I know what you mean though, I lost one of mine. As long as you have two though you'll be fine, just use them in opposite corners. Have one in the top-left, and the other in the bottom-right...should be fine.
What did you do to the shift ****??? Also, JD's right...you can get a shift **** for cheap from Thorsten. And he gets it to you QUICK from Germany.
Old Aug 18, 2004 | 04:53 AM
Default plus he can get you anything imaginable....
the guy is amazing, so is his work
Old Aug 18, 2004 | 05:21 AM
Elder Member
Default Hmm...
xenon+ perhaps?
Hehehe...I'm already on it. He's working to see if he can get a few, but they are expensive he says.
Old Aug 18, 2004 | 05:30 AM
that they are
Old Aug 18, 2004 | 08:44 AM
mindtrip's Avatar
Default I already have his boot but.....
on the **** itself there are 4 black plastic clips that hold it onto the shifter I broke 2 of them off. He makes new shift *****? I didnt even knwo that I liek the stock one only thing I would consider is doing the shift **** out of the Convertable S4
I do only have 2 of the clips the other ones are lost. Its way to loose I really just wanted to order new ones. So any one with the Bently manual it would really help if you could look up the part number, also I need the # for the trim above the steerign wheel inbetween the buttons to control the display "For toy guy style mod"
devolab
Audi allroad
Aug 29, 2006 04:14 AM
Dr. Moro
Dec 17, 2003 07:25 AM
MarkFank
Audi allroad
Aug 22, 2001 12:48 PM
jcrouse
Mar 13, 2000 09:55 AM
