S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Travel question for the Philly/NJ crowd
Old Dec 14, 2004 | 05:02 AM
jmsod's Avatar
Junior Member
Default Travel question for the Philly/NJ crowd
I have to commute tomorrow am from Mt. Laurel, NJ to King of Prussia. Need to be in KoP at about 7:15. Will the Schuylkill expressway be ok at that time? Probably hit the BF bridge around 6:45 or so. Or better off just going the NJ to PA turnpike? Thanks.
Old Dec 14, 2004 | 05:09 AM
JDBlueAudiS4's Avatar
Default The surekill always sucks...
I would vote for the turnpike, it seems to have less bottle necks, also not having to go right through philly is a lot better. If you hit the bridge at 6:45 I highly doubt you will make it to KOP by 7:15.
Old Dec 14, 2004 | 05:19 AM
jmsod's Avatar
Junior Member
Default Thanks... I thought if I hit the bridge that early then it
would not be too bad. I guess I am a little optomistic thinking it will only take 30 minutes from the BF bridge to KoP. TP route is about an extra 20 miles I think.
Old Dec 14, 2004 | 06:45 AM
NJRickD's Avatar
Default I would take the surekill if you're going that early.
The NJTP to PATP is an extra 25 miles. That is definitely an option if there is a major backup or accident on the schuylkill, but that route will take you longer if you're just looking at normal backups. I would be at the bridge at 6:30 though, just to be safe. The PATP is option C for me. Option A being the schuylkill, option B is Walt Whitman, 95 south to the blue route to the schuylkill, option C NJTP to PATP.
Old Dec 14, 2004 | 07:08 AM
jmsod's Avatar
Junior Member
Default Good advice .. thanks..
I always forget about the WW bridge. Not sure why. I'll try to hit the BF by 6:30. Thanks
Old Dec 14, 2004 | 09:30 AM
CSCOKid's Avatar
Default conshy to downtown...
if i have a 6:50 train i leave the house at 6:15 and get there with 10-15 minutes to spare. kop is another 10 minutes past me. if your over the BF by 6:30ish at the latest you should be fine.
2PUTT
NY / NJ / CT Discussion
Aug 22, 2008 02:16 PM
caster
Jul 27, 2003 01:30 PM
Er-excess-4
May 2, 2002 03:26 PM
Dead
Jan 12, 2002 07:22 AM
