S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Shifter
Old Dec 14, 2004 | 11:24 AM
Dentaltech's Avatar
Default Shifter
On the manuel trans does the shifter ****/ sheath actually just press fit on the shaft? I did a speed shift last night and pull 2nd gear hard and I popped it off. It snaps right back in place but it seems very odd to me. I hate to have to go take it to the dealer to check this out and I know you guys know all the answers so post away.
Thanks
Old Dec 14, 2004 | 11:37 AM
HarnessedLunacy's Avatar
It just slides on and has a little band clamp to hold it in place
Old Dec 14, 2004 | 11:42 AM
Dentaltech's Avatar
So does my description make it sound like mine is fubared?
Old Dec 14, 2004 | 11:45 AM
MachtigAvant (v3.0)'s Avatar
Elder Member
Default Yea, even if the clamp is on there, there's a chance it will come off.
Learn to shift smoothly and you'll be fine. ;-)
Quick!! But smoothly... ;-)
Old Dec 14, 2004 | 11:49 AM
04 Savant's Avatar
Go buy a new clamp or tie and you can do it yourself.
Old Dec 14, 2004 | 12:13 PM
Dentaltech's Avatar
How do you get under the leather boot?
Old Dec 14, 2004 | 12:19 PM
04 Savant's Avatar
Default The chrome trim around the base of the boot is flexible plastic. Just...
GENTLY push it inwards (toward the shifter) and the two tabs should pop free, allowing you to pull the boot up over the ****. This will reveal the base of the **** which you will see, aligns with a groove in the shaft to keep it in place. Just put a new clamp of plastic tie around the base and tighten. Good as new!
Default If you take a look at the Stratmosphere short shifter instructions, figure 2 shows the band clamp
It will probably be tough to tell if yours is messed up (fubared) without lifting up the shift boot and checking it out.
If it is messed up, you can replace the band clamp with a new one or a zip tie.<ul><li><a href="http://www.stratmosphere.com/audi%20short%20shift%20kit%20S4%202004%20V8.pdf">S trat short shifter installation</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 14, 2004 | 12:37 PM
Dentaltech's Avatar
Thanks guys, Is this a common problem? This is a new 05 Avant. Or am I a gorilla?
Old Dec 14, 2004 | 02:22 PM
S4Tuned's Avatar
AudiWorld Expert
Exactly. Jamming the shifter into gears doesn't make you faster!
