S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Second Try: Anybody use the Escort GT-2 performance timer?
Old Dec 14, 2004 | 07:25 PM
Miah_S4Avant's Avatar
Default Second Try: Anybody use the Escort GT-2 performance timer?
What settings did you use for the pitch forward and back and side to side? Any other settings that should be adjusted?
Old Dec 14, 2004 | 07:28 PM
doomed's Avatar
AudiWorld Expert
I had a Plymouth Horizon in high school....
Old Dec 14, 2004 | 08:21 PM
jpc-S4's Avatar
ROFL!!!
Old Dec 14, 2004 | 08:38 PM
ESFO's Avatar
Default bad Doomed....
And ewwww, that's a nasty sig pic... I like your car better. ))
Old Dec 15, 2004 | 03:35 AM
frankk's Avatar
Junior Member
Default gtimer settings
I think the factor defaults (2 and 3) are fine for our cars. I changed the Speed and 1/4 Mile "Rollout" to 0 (zero) from 12". If you don't change Rollout, you'll get very optimistic launch times (0-60, 1/4 mile). AW's CSBM5 help me with the rollout a few months back.
Old Dec 15, 2004 | 03:55 AM
Arnzo's Avatar
Junior Member
LOL :-)
Old Dec 15, 2004 | 09:21 AM
Default Thanks frank. According to the manual drag strips use rollout, is this true?
If so, it would be more accurate to have some no?
Old Dec 15, 2004 | 06:30 PM
frankk's Avatar
Junior Member
Default At a strip...
there's a light beam about 2" off the ground. When you line up, your tire breaks the beam. If you stop with the beam at the front of your tire the timer will not start until the tire leaves the beam...that's about 12" from the front of your tire to the back (at 2" off the ground). This will give you better elapsed time (but won't necessarily get you to the finish line first).
The difference between 0 and 12" is about .4 seconds. On a good run I'll see a 5.2*. With the rollout set to 12" I can break 5 seconds (I've seen 4.8*) which sounds great but it's unrealistic. It's amazing how much time it takes to move the first 12".
 Pouria Savadkouei
 Michael S. Palmer
Benzie
Audi allroad
Feb 4, 2010 07:13 PM
fl2.7T
Auto Detailing Discussion
May 9, 2003 08:44 AM
hsjb
Wheels & Tires Discussion
Aug 22, 2001 07:45 AM
Trip_McNeely
Oct 31, 2000 04:46 PM
Hal
Jun 10, 1999 05:31 AM
