S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
e-code turn signals
Old Dec 16, 2004 | 04:36 AM
ssTechnik's Avatar
New Member
Default e-code turn signals
What's everyone's experience with the turn signal bulb? Should I go with the double or single filament when I replace the bulbs? Will the double fry the housing if they're on too long? Frequently drive with lights on during the day. Installed the Valeo euro housings. Thx for the feedback.
Old Dec 16, 2004 | 05:02 AM
MachtigAvant (v3.0)'s Avatar
Elder Member
Default If your doing e-codes single filament is your only decision...
Get some Silvervision bulbs by Philips and be done with it.
Old Dec 16, 2004 | 06:54 AM
ssTechnik's Avatar
New Member
Default Re: If your doing e-codes single filament is your only decision...
But don't I need a 3457 wedge base for the front and I don't think the silvervision comes in a wedge? Car is at the shop having a number of things done and I haven't seen the harness/connector...small shop and the owner is out a few days for training, so I can't check it out until Sat...thx for your patience!
Old Dec 16, 2004 | 07:46 AM
Elder Member
Default Ok, well, if your installing e-codes, your stock turn bulbs are not going to work.
If you are installing e-codes, then you are going to need a push-design Silvervision. You would use dual-filament wedge designs with the stock units, or with the clear corner mod. If your using a genuine e-code housing, your going to need the philips silvervisions.
sIcAoNe
9
May 7, 2003 01:40 PM
RA121125
Apr 24, 2003 10:54 PM
TwiceBlown
9
Aug 31, 2002 04:11 PM
brian@avalonmotorsports
13
Dec 3, 2001 10:49 AM
audiophilitis
Sep 14, 2001 08:32 PM
