S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
DP's and long term effects...
Old Dec 17, 2004 | 11:19 AM
kujo's Avatar
Default DP's and long term effects...
Can DP's and Full back exhausts have ill effects in the long term?
Meaning if I go with DP's on top of my intake and Res Milltek, in 2-3 years, is that putting excessive wear/tear on the motor ?
Or is it just more air going through with NO negative effects on the wear of the motor ?
Sorry if this is a stupid question, but....
thanks,
kj
Old Dec 17, 2004 | 11:21 AM
ESFO's Avatar
Default Zero negative effect.
The air pump (engine) is simply allowed to operate more efficiently rather than operating with an artificial restriction.
Old Dec 17, 2004 | 11:23 AM
MachtigAvant (v3.0)'s Avatar
Elder Member
Default You'll be fine...
the extra flow is actually taken less of a load on the engine to push that exhaust out. So the engine works less. So your engine lasts longer, etc, etc. ;-)
Old Dec 17, 2004 | 11:30 AM
Captain Sheetmetal's Avatar
Senior Member
Default If there is an appreciable power increase, there will be more wear on the drivetrain.
You will have more clutch wear, transmission wear etc,...in theory. But I wouldn't imagine that it would be a difference that would make a difference, especially over the next three years.
Old Dec 17, 2004 | 11:42 AM
CT04S4's Avatar
New Member
That's how the RS4 will get part of it's HP increase.
Old Dec 17, 2004 | 02:42 PM
sneaky blk mushro.Om's Avatar
Member
Default News to me.. then why do most Audi technicians say it voids warranty?
Is it the install process?
Old Dec 17, 2004 | 03:32 PM
Shiloh's Avatar
New Member
Default do most tech say that?
The local Audi techs told me that it would not void the warranty. They said it would be no problem to do DP, catback, intake, and chip. I guess it must from one dealership to another.
Old Dec 17, 2004 | 04:12 PM
davyk3's Avatar
Member
Default since the downpipes lead directly to the engine, so if your engine goes blah
they can say, see its your fault, the downpipes! its' the god damn downpipes! (even though it isn't)
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 17, 2004 | 05:08 PM
04 Savant's Avatar
Don't forget, when you replace the DPs you replace the cats as well!
Old Dec 17, 2004 | 08:07 PM
Member
you in socal?
