I've seem 2 posts in the past 2 days about VAGing away the seatbelt beep
Select]
[17 - Instruments]
Enter 5-digit code from below
___________________________________
Mine was coded to 01231.
Recoded to 01229. No more seat gong.
I took this from posts I found while searching for the same answer. It worked like a charm and took my mechanic "s4master" about 2 minutes.
I don't know whether or not the dealer will do it for you.
* https://forums.audiworld.com/s4b6/msgs/102021.phtml
Damon
late '04 S4 Avant 6MT
04' KTM 540 Supermotard
Recoded to 01229. No more seatbelt chime.
Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
Look at the third digit in the coding (Market version):
0 - "Germany" 24 hour clock
1 - "Rest of World" 24 hour clock
2 - "USA" 12 hour clock
3 - "Canada" 12 hour clock<ul><li><a href="https://forums.audiworld.com/s4b6/msgs/102021.phtml">Original post</a></li></ul>
