S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Can anyone explain the difference between the 04/05 intake and exhaust...
Old Dec 18, 2004 | 05:59 PM
TurboLust's Avatar
Junior Member
Default Can anyone explain the difference between the 04/05 intake and exhaust...
What is the intake flap and where is it. Were the exhaust valves taken off the 05's? The valves were for opening different channels @ different RPM's for varying flow, I'm assuming?
Old Dec 18, 2004 | 06:07 PM
sneaky blk mushro.Om's Avatar
Member
0 reponses and 0 difference.
Old Dec 18, 2004 | 06:08 PM
TurboLust's Avatar
Junior Member
Default Re: 0 reponses and 0 difference.
There's differences. Are you kidding or do you just not know?
Old Dec 18, 2004 | 06:10 PM
Pleasanton 335's Avatar
Default Both intake and exhaust are diff...
Minor differences. The Exhaust no longer has the "flaps" that change exhaust note. Not sure what changes happened with the intake, but I hear that there were some minor ones.
Cheers.
Old Dec 18, 2004 | 06:11 PM
Member
i must be ignorant, then.
Old Dec 18, 2004 | 06:21 PM
Schadenfreude's Avatar
Not even all 04's have exhaust flaps. Not sure about intake changes for 05
TurboLust's Avatar
Junior Member
Default Ha! Wusifer!
Talk to the hand! J/K dude.
Old Dec 18, 2004 | 06:24 PM
SecureS4's Avatar
Default Check here..........
<center><img src="https://www.audiworld.com/features/tests/2004_s4_002.jpg"></center><p><ul><li><a href="https://forums.audiworld.com/s4b6/msgs/167741.phtml">Exhaust Flap discussion</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 18, 2004 | 06:25 PM
TurboLust's Avatar
Junior Member
Default Re: Both intake and exhaust are diff...
Is that good or bad for 05's in the sense that, did the flap give it a better sound @ diff levels of power?
Old Dec 18, 2004 | 06:30 PM
TurboLust's Avatar
Junior Member
Default Re: Check here..........
Real nice illustration. Thanks. It seems like it should be the other way around, w/ the flap opening under harder acceleration. So the 05 has d/c'd the flap; does that mean the system is more open in all conditions now?
