S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
ESP Problem
Old Mar 6, 2005 | 07:05 AM
audis4bachelor's Avatar
Default ESP Problem
I had a 2004 a6 4.2 and never had a problem with my ESP, but now I have a 2005 S4 Tip. When I am at a full stop and floor it, the ESP kicks in a the engine bogs. This is in sport, regular and tip. Now if I turn ESP off it does not do that, but should I have to? I dont think I should have to shut it off just to floor it off the line. Has anyone else got a fix for this other than esp off?
Old Mar 6, 2005 | 07:25 AM
UnBrilliantBarry's Avatar
Member
get a mt6
Old Mar 6, 2005 | 07:35 AM
DrGP's Avatar
Banned
Default With a 6 spd, for max performance, we turn the ESP off. BUT
If you don't turn it off the car still accelerates without a problem. Don't really know if this is an issue with other tip cars.
Old Mar 6, 2005 | 07:43 AM
Blau Flash's Avatar
Member
same method applies to Tip's, ESP OFF
Old Mar 6, 2005 | 07:49 AM
gregmag's Avatar
Default My technique
<ul><li><a href="https://forums.audiworld.com/s4b6/msgs/178889.phtml">https://forums.audiworld.com/s4b6/msgs/178889.phtml</a</li></ul>
Old Mar 6, 2005 | 07:55 AM
larrycr's Avatar
Default My A6 4.2 experience is
My A6 4.2 had something similar going on. If (all with my right foot) I went from the brake pedal to quickly nail the throttle the car would go into extreme hesitation mode. Just about got creamed a few times while pulling into traffic. I found that if I paused ever so slightly between the brake release and the throttle application the problem went away.
Old Mar 6, 2005 | 08:16 AM
ToastR's Avatar
Default I'm convinced the "chop throttle" effect is
one of the driving nannies intervening via DBW, but I don't think it is necessarily related to wheelspin as you would expect if ESP was intervening. I don't think all of the instances in which I experienced the "chop throttle" nonsense would have been due to wheelspin such as on dry pavement- so I think something else is going on too.
ESP off is the only way I have found to prevent it. If we get excessive wheelspin in our tips, it'll shift out of 1st gear into 2nd and that'll cause a pretty good lurch too.... unfortunately its impossible to hold revs close to redline for us.
I have noticed I get better launches in S mode tho. I feels like the DBW gives something closer to max throttle from a stop in S than in Tip mode, cause the car seems to leap away more quickly.
Anyone else do any experimentation with that?
Old Mar 6, 2005 | 09:12 AM
gregmag's Avatar
Default Want a real rush..
I just got Revo'd. Cranked up the throttle response (boost in the manual) to "9" with an SPS-3. HOLY !@#!@. Doesn't feel like a "9", feels like an "11".
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 6, 2005 | 09:23 AM
Member
what is this 9 and 11
Old Mar 6, 2005 | 09:34 AM
gregmag's Avatar
Default 9 is a setting on a Revo SPS. 11 is a lame Spinal Tap joke
<ul><li><a href="http://www.revotechnik.com/products/pdf/sps.pdf">http://www.revotechnik.com/products/pdf/sps.pdf</a</li></ul>
