S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
strat. ShortShifter Problems
Old Feb 9, 2006 | 07:22 AM
gtikid98's Avatar
Default strat. ShortShifter Problems
I installed the shifter about a week+ back, and I made sure all bolts were torqued. everything was fine and dandy until about 2 days back when reverse became difficult to engage. then yesterday the ring clip for the spring slipped out and every time i place it back in place it lasts for about 5 pushes to get it into reverse and slips out. Any one have any helpful advice, complaints, any input at all about the shifter.
Thanks for your help...
Old Feb 9, 2006 | 07:30 AM
JDBlueAudiS4's Avatar
Default Sounds like you damaged the circlip during the install...
and it needs to be replaced. I believe they include 2 replacement circlips with the shifter. Also did you use loctite on the lower bolt? If not then thats you problem. The lower bolt that connects the shifter to the shift elbow is loose and allowing there to be play in it which makes reverse hard. You need to pull the shifter out and fix both of these things and then you should be fine.
Old Feb 9, 2006 | 07:41 AM
gtikid98's Avatar
Thanks for the help
Old Feb 9, 2006 | 07:42 AM
anytime
Old Feb 9, 2006 | 11:53 AM
s4for5_TTfor2's Avatar
I did not get any extra clips with mine
Old Feb 9, 2006 | 02:03 PM
Default email me your address and I will send you some...
I bought a bag of 100 back when I was doing lots of these installs.
bcr84urq
Nov 21, 2006 07:22 AM
pacho
Apr 12, 2006 09:39 AM
[tri]liament
May 10, 2005 07:32 PM
Black 1.8 Turbo
Aug 16, 2004 03:05 PM
apexalex
12
Apr 9, 2002 05:22 PM
