S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Why would anyone upgrade to 6 piston brakes with 14.5" rotors? (long)
Old Feb 9, 2006 | 07:33 AM
CA_Dan's Avatar
Default Why would anyone upgrade to 6 piston brakes with 14.5" rotors? (long)
Before I get lambasted, here is my thought process:
1) The stock brakes apply enough force to lock up the ABS, so they have adequate stopping power. Stopping distance is more a factor of tire grip than brake system ability at this point (although repeatability becomes a concern after brake fade sets in).
2) The main advantages to upgrading to aftermarket brakes is a reduction in unsprung weight and brake fade. A secondary advantage is improved pedal feel.
3) Wouldn't it make sense then, that the smallest diameter aftermarket rotor with the smallest caliper capable of producing stock stopping force while increasing cooling would be best? This would be the lightest settup while still having increased cooling and better pedal feel.
I starting thinking about this while considering either the Stasis track sport (4 piston) or motor sport (6 piston) brakes. I notice they have an option for 13" rotors at a reduced cost. Help me understand what I'm missing here.
Old Feb 9, 2006 | 07:38 AM
2PUTT's Avatar
Default overview...
<ul><li><a href="https://forums.audiworld.com/s4b6/msgs/327946.phtml">BRAKES INFO</a></li></ul>
Old Feb 9, 2006 | 07:45 AM
VerrÜckt's Avatar
Default Audis are fat cars. You're not going to get real track performance and fade resistance with
anything but huge brakes.
You're right though, you should buy no bigger brakes than you need. But, with heavy cars, the brakes you need for any sort of real track driving are rather large.
CA_Dan's Avatar
Default I know, I read this when it was posted. There were 2 schools of thought...
One was that more brake system mass results in better heat soak and better cooling. The other was that less brake mass results in quicker cooling. The discussion of slotted vs drilled was right on, and that's not what I'm questioning. I just don't see how larger calipers and rotors would be an advantage when a car doesn't have 10 inch wide tires to apply the stopping force.
Old Feb 9, 2006 | 07:47 AM
CA_Dan's Avatar
How can bigger calipers reduce fade? Better rotors, ok. But calipers?
VerrÜckt's Avatar
Default Brakes need mass. More mass is more thermal capacity. Stock brakes can be made to fade
pretty easily on the track and at Autobahn speeds.
Old Feb 9, 2006 | 07:48 AM
VerrÜckt's Avatar
A larger caliper accepts a larger pad. Larger pads run cooler and wear less.
Old Feb 9, 2006 | 07:51 AM
VerrÜckt's Avatar
Default And pistons don't necessarily directly correlate to brake size. Here is a 10 piston brake...
<center><img src="http://www.regalshop.co.uk/asps/uploads/big/2901-1.jpg"></center><p>that is smaller in size than a stock S4 braking system.
More pistons provide more even pad force distribution.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 9, 2006 | 07:56 AM
CA_Dan's Avatar
Makes sense, so the only advantage to more pistons (all else held equal) is better pad wear.
Old Feb 9, 2006 | 07:58 AM
CA_Dan's Avatar
Yes, but is the offset in unsprung mass worth the marginal increased cooling?
