Exhaust Question
Old Oct 19, 2004 | 05:47 PM
Fresh1's Avatar
New Member
Default Exhaust Question
I just want to confirm...
As i have a chipped audi a4 1.8T quuattro and i will be getting a FMIC aswell.. will it be best for me to get a 3 inch exhaust system (turbo back of course) orrrr a 2.5 inch system??
I've heard good and bad things about both and i just want to know straight out which one would be best for my car!
So far i have decided to go turbo dump pipe, high flow cat (with fire ring) all mandrel bent in mild steel and custom stainless steel mufflers but i havent decided what size piping is best yet... any advice would be appreciated.
cheers guys
Old Oct 19, 2004 | 08:55 PM
AUDIOZ A4's Avatar
Default DEFINATELY 3" - I had a 2.5" system - and just had it ripped out for for a 3" system
And make sure you **** off the stock cat and get a hi flo unit under the car. The stock Cat is a cork.
3" is a BIG improvment of 2.5" - I can say this as I have actually now had both.
Old Oct 19, 2004 | 10:01 PM
Fresh1's Avatar
New Member
Default Re: DEFINATELY 3" - I had a 2.5" system - and just had it ripped out for for a 3" system
oh cheers man! at last somone can give me a straight answer! with some proof that they know what the difference is
Old Oct 19, 2004 | 11:02 PM
AUDIOZ A4's Avatar
Default Just further to this:
I had a CAT back 2.5" system for about a year - it was good (much better than stock) - but the real improvement in throttle response and top end came from changing over to turbo back and 3" with a hi flo cat under the car.
My advice: Dont waste your money like I did- do it properly the first time and get 3".
Old Oct 20, 2004 | 12:48 AM
RS4@LAST's Avatar
Default Re: Exhaust Question
and who is gonna remap your ECU ? I hope you have planned for this..
Old Oct 20, 2004 | 04:30 AM
AUDIOZ A4's Avatar
Default He wont need a ECU remap unless his car is DBW
Even then he doesnt need an ECU re-map.
his worst case scenario if he is Drive By wire (like ur RS4) is that his computer will throw a CEL error. But given NONE of the B5 A4's are DBW in Australia - its not an issue.
Old Oct 20, 2004 | 09:47 AM
RS4@LAST's Avatar
Default What ! are you crazy
of course he'll need a remap. His WOT works off a fixed map. DBW or NonDBW.
on my 01 A4 TQ (180hp), i installed a Milltek Downpipe (along with the exhuast). I had to uninstall it, as it dropped hp and ran lean at WOT. I was lucky enough to dyno before and after every mod.
You dont need a remmapif your doing the middle and rear exhaust, as the flow rate change is within the spec, but as soon as you change the DP, and especially if you de-cat, screwed, remap needed. Else, major engine damage awaiting, not to mention marginal peformance.
Better he learns now. But then you ask the hard question, who can remap in AU. Start with Lucus and his GIAC relationship.
Old Oct 20, 2004 | 04:10 PM
AUDIOZ A4's Avatar
Default Do you have any clue at all?
Air / Fuel is determined by the Mass air flow meter detecting the amount of air coming into the engine, which the ECU reads and adds the correct amount of fuel.
Tell me this? How are all the Audi's running around with after market exhausts not pinging? Because I can tell you they all certainly dont have remapped ECU's.
And why does my own car register a perfect air/ful curve on the dyno? I havent had my ECU remapped for my exhaust!
Its this sort of BS that causes problems and puts uncertainty in peoples minds - just do a search on exhausts and that will confirm what I have told you.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 20, 2004 | 04:41 PM
Lucas_Gchips's Avatar
Default Re: What ! are you crazy
Well depends on chip to start with.
But with our chips we have never needed to remap for exhaust.
This all comes down to how many modification are actually done to the chip to start with.
Some chips on market have very minimal parameter changes just to give you some more power.
Some chips have a lot of work don to them and are virtually a re-write of the code.
Old Oct 20, 2004 | 06:42 PM
Fresh1's Avatar
New Member
Default Re: HAHAHA oh my god!
what the hell should i do now....
split decision and i dont have a clue whos right hahaha
Maybe i should just call audi here in perth they might be able to tell me whether i will need an ECU re map. Although none of the exhaust places (even the one who does the exhausts for audi here in perth) have said anything about re-mappinbg me ECU....
so what do i do now?
