Josh this is what your looking for - CARBONIO!
Old Nov 17, 2004 | 02:09 AM
Quattro4lifeAus's Avatar
Member
Default Josh this is what your looking for - CARBONIO!
<center><img src="http://carboniointakes.com/a4/b5/b5_image1.jpg"></center><p>You have probable found it already but just in case you haven't.
Not to sure on the design but it has the bling factor.
Might work out cheaper than CDA System considering the exchange rate.<ul><li><a href="http://carboniointakes.com/a4/a4_b5.php">http://carboniointakes.com/a4/a4_b5.php</a</li></ul>
Old Nov 17, 2004 | 03:38 AM
AUDIOZ A4's Avatar
Default Re: Josh this is what your looking for - CARBONIO!
Thanks - I hadnt actually seen that one before.
I actually dont like the design much - the intake 'snorkel' looks unecessarily long and there actual chamber looks small.
Not to keen on the text description either "K&amp;N type" in other words a cheap copy.
I might be wrong - but I suspect a looks first performance second with that kit. (but I could well be wrong).
Does anyone here have this kit?
Ive more or less decided to go with a K&amp;N pod and build a custom cold air box in polished aluminium. That way I can get the volume I want with all the heat shielding I want and the looks I want. Ive put some thought into it and will use the original air intake from the front grill into the box - and have the box open underneath with some piping to the very bottom front grill for good air flow. Im going to run this idea past a few perormance places and see what they think.
Old Nov 17, 2004 | 04:14 PM
SilverPas's Avatar
New Member
Josh if your going to get a pod I would suggest a BMC pod over K&amp;N, overall the BMC is a better product.
linust
Sep 30, 2015 06:14 AM
jyoteen
Dec 3, 2000 02:31 PM
Rich_W
Nov 8, 2000 09:47 AM
Josh L
Jul 13, 2000 02:22 PM
