Valentine One Stealth Display...done!!! - ->
This install is the same for the B6/B7 A4 and S4 and is faily similar with the <a href="http://images15.fotki.com/v232/photos/4/43687/1119528/20051130006-vi.jpg">C5 A6, RS6 and All Road</a> and started life as a kit for the <a href="https://forums.audiworld.com/s4/msgs/1693256.phtml">B5 A4 & S4</a>
He started with a basic Valentine One, wired to the Cig Lighter...
I recv'd his stock steering wheel trim about two or so weeks ago along with his Concealed Display.
I started with a custom made housing that will replace the Concealed Display..and modified it further to work with the B6 steering wheel trim, applied, the appropriate color and, shown here with protective paper still applied to the lens...
<img src="http://images16.fotki.com/v271/photos/4/43687/3213377/KipsB6S403-vi.jpg">
I modified the original Concealed Display so it could be integrated into the housing, did some mods to the dash so as to allow the housing assmbly to install properly and to be able to get the wiring done..
<img src="http://images16.fotki.com/v277/photos/4/43687/3213377/KipsB6S404-vi.jpg">
We ran another set of wires over to the center console to be able to mount the remote mute button..
<img src="http://images16.fotki.com/v271/photos/4/43687/3213377/KipsB6S405-vi.jpg">
Kip chose the uber concealed mute button location inside the shift boot, so I mounted the button inside the boot..
<img src="http://images16.fotki.com/v270/photos/4/43687/3213377/KipsB6S406-vi.jpg">
There is a quick disconnect so the boot, **** and shifter surround can be removed easily..
<img src="http://images16.fotki.com/v282/photos/4/43687/3213377/KipsB6S408-vi.jpg">
You can't ask for it to any cleaner of an install then this..the mute button is located inside the boot so all you need to do is drop you fingers inside the valley in the front of the shift boot and press..
<img src="http://images16.fotki.com/v282/photos/4/43687/3213377/KipsB6S409-vi.jpg">
The finished product...
<img src="http://images16.fotki.com/v271/photos/4/43687/3213377/KipsB6S410-vi.jpg">
<img src="http://images16.fotki.com/v273/photos/4/43687/3213377/KipsB6S411-vi.jpg">
Next on the list the remote audio controls...this can be added at any time as the pieces are totally modular. This setup has the remote audio and speaker in one piece of trim, but if you have the security light control as an option there are other locations to mount the audio controls as well..
<img src="http://images16.fotki.com/v270/photos/4/43687/3213377/KipsB6S413-vi.jpg">
<img src="http://images16.fotki.com/v273/photos/4/43687/1119528/B6V1059s-vi.jpg">
Now he is cruising ultra stealthy!! We also did the hard wire install so he no longer has to deal with cig lighter power cord!!
Enjoy!!!
