DRL Light Bulb Pics (LED vs. Amber)
Both bulbs work great and light up well. The super white matches perfectly to the Bi-Xenon HID headlights and looks good in the headlamp housing. The yellow bulb is bright and looks good as well, a true yellow/gold look that isn't faded or bland looking like my H11 foglight bulbs. I never drive with the DRLs on so I figure I would just leave either set in.
Here's the problem. Both bulbs light up great, but the LEDs don't draw much power. LEDs don't draw much power in general. Because of this, the car's computer throws the error on the cluster saying that the bulb is out and needs to be changed and leaves an annoying picture of a bulb with a 'X' through it right in the middle of the cluster. So I took them out after about 2 minutes of use. I put the yellow ones in there and drove around with it for an hour with the DRLs on. No burnouts, no color fading, no error messages on my cluster. So I just left those in there for now. I guess the only way to run the LEDs would be to either find a set that draws more current so it doesn't throw an error message, or to some how VAG the computer into not displaying 'bulb out' messages.
Here are some quick pics I took up close of the bulbs. From a distance and in person, they both look much better looking on the car.
<img src="http://www.jdm****.com/A4drl/02.jpg">
<img src="http://www.jdm****.com/A4drl/21.jpg">
<img src="http://www.jdm****.com/A4drl/04.jpg">
<img src="http://www.jdm****.com/A4drl/19.jpg">
<img src="http://www.jdm****.com/A4drl/09.jpg">
<img src="http://www.jdm****.com/A4drl/08.jpg">
<img src="http://www.jdm****.com/A4drl/15.jpg">
<img src="http://www.jdm****.com/A4foglight/images/35.jpg">
EDIT: I just found <b><a href="https://forums.audiworld.com/a4gen2/msgs/610739.phtml">THIS LINK</a></b> here that shows adding a load equalizer will solve the problem. Now, if I feel like getting it and splicing it in, I'll run the LEDs. But since I never run my DRLs, I'll probably just pass on this project.
I know that some put LED's in place of the city lights, but not in place of high beam halogens.
