A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Old Aug 12, 2016, 08:05 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A4 (B7) Steering & Suspension Guides
Print Wikipost
steering wheel off after alignment?
Old Jan 11, 2007 | 09:57 PM
a4b76m's Avatar
New Member
Default steering wheel off after alignment?
I just had my car aligned after playing with my ride height and i noticed that the steering wheel is pointing to the left 15 degrees or so. I called the alignment shop and they said they have no idea what is wrong with it and to bring the car back in next week. This is my second alignment in 6 months and the first was fine, but was done somewhere else. Anyone have any idea how to fix this or what happened?. I'd rather check here before giving it back to those guys. Thanks
Old Jan 11, 2007 | 10:28 PM
pierreb's Avatar
Cat Herder
Default sounds like a easy fix.
<ul><li><a href="http://www.familycar.com/Alignment.htm#Steering%20Center">steering</a></li></ul>
Old Jan 12, 2007 | 03:53 AM
Audi2.0TFSI's Avatar
Default If your steering wheel is offset then your car is not aligned correctly.
Audis are very difficult cars to aligin due to the multi-link suspension setup and raised toe adjustment.
The car may be "within" spec to the aligment machine, but it cannot be aligned correctly with the steering wheel offest and you will wear tires faster.
Old Jan 12, 2007 | 05:33 AM
Tgr_Clw's Avatar
AudiWorld Uber User
A good alignment shop will align your steering wheel (it's part of the alignment process).
Old Jan 12, 2007 | 06:42 AM
Default Audi dealers use a steering wheel lock (As explained to me when the F'd up the alignment on my '98)
And in my case it was "not correctly installed" hence why the steering wheel was mis-aligned.
VICTORY AUDI in HARRISBURG PA SUCKS!!! (So bad in fact that I drive 40 MINUTES to Lancaster, PA for EVERYTHING.)
Old Jan 12, 2007 | 06:43 AM
edkwok's Avatar
Default Re: steering wheel off after alignment?
Alignment is covered in first 12,000 miles from factory. Take it back to dealership if you haven't gone over the limit
Old Jan 12, 2007 | 10:08 AM
a4b76m's Avatar
New Member
I'm on C.O.'s so I don't think the dealership will do anything.
Old Jan 15, 2007 | 08:26 AM
quattrothatcould's Avatar
Default My steering wheels is offset slightly to the left but the important thing is that your car..
tracks straight when you drive
 Pouria Savadkouei
 Michael S. Palmer
coldcrow
Wheels & Tires Discussion
Nov 17, 2011 03:59 PM
audi49
Dec 28, 2005 12:58 PM
chuckyarla
Nov 19, 2005 07:14 AM
OldSkewS4
Audi Original "S" Cars
13
Jul 13, 2004 06:39 AM
jyoteen
Feb 5, 2002 06:50 AM
