A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
my brakes suddenly started squeeking at 7,000 miles. can anyone explain why??
Old Jan 13, 2007 | 05:02 PM
kpisafterme's Avatar
Old Jan 13, 2007 | 05:13 PM
Big D's Avatar
Member
Default I'm sure the dealer could explain why...
as well as fixing them under warranty.
Old Jan 13, 2007 | 09:21 PM
JamezHill's Avatar
New Member
Default Re: my brakes suddenly started squeeking at 7,000 miles. can anyone explain why??
I had the exact same problem when I brought it in for my 5k. They said it was brake dust. Still have a squeal...
Old Jan 14, 2007 | 07:51 AM
Bob Loblaw's Avatar
Senior Member
Default From my experience, don't tell the dealer they are squeaking, tell them they are griding
or some other noise. I know a mechanic who said that squeaking brakes are 'normal' for cars, 'grinding' is not (or choose another type of sound other than 'grinding').
If they are going to do any investigation or work on the car, a customer comment reported as 'grinding' provides more ground for the dealer to charge AoA for warranty repair than for 'squeaking'.
Old Jan 14, 2007 | 10:19 AM
GermanCarBuff's Avatar
Default Try bedding the brakes to remove the layer of pad material that could be causing the squeaking.
<ul><li><a href="http://www.pagidusa.com/bedding_in_procedure.htm">http://www.pagidusa.com/bedding_in_procedure.htm</a</li></ul>
Old Jan 14, 2007 | 01:15 PM
DaveJJ's Avatar
New Member
Just a thought, my girlfriends' G35 had a squeak around 9K. I checked it out and there was rust build up/clog on the pads (not too bad since braking usually rubs off most of it but still enough to squeak). I just sanded it down a little and the sound went away.
Old Jan 16, 2007 | 05:19 AM
cdl5583's Avatar
New Member
stfa
Richard Ballard
S6 / RS6 (C7 Platform) Discussion
10
Jan 14, 2018 09:52 AM
ilans1
Q7 MK 1 Discussion
31
Feb 23, 2009 01:50 PM
Dave_4
Mar 23, 2003 03:35 PM
phoolan
Nov 25, 2000 10:45 AM
yatyaS4
Oct 5, 2000 07:57 AM
