A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
ABT chip+turbo rudimentary test
Old Jan 13, 2007 | 07:34 PM
DukeLeto's Avatar
Default ABT chip+turbo rudimentary test
I just did a primitive 0-62mph test in my newly modified 275HP 2.0T(i.e. a friend was using a stopwatch to time my 0-62mph times) and out of 5 runs 2 were under 6.5s, 2 under 6.4s and one under 6.3s.
I plan on also changing my exhaust. Do you think I will see an improvement of under 6 seconds per 0-62 times?
If anyone is wondering, the car is running great and the new turbine is not much louder than the old one.
Opinions much appreciated,
T.
Old Jan 13, 2007 | 08:17 PM
bhvrdr's Avatar
Default Is it a tip car? I have seen sub 6 second times with just a chip but it was a 6-speed...
with regards to exhaust, i think the gains will be minimal once the car is fully optimized with a flash until the fueling is upgraded.
Old Jan 14, 2007 | 12:52 AM
SANS RICE's Avatar
primitive indeed - props to your friend for being precise to ~ .3 second - as for accuracy...
Old Jan 14, 2007 | 06:10 AM
Audi2.0TFSI's Avatar
Default LINKY LINKY!!
<a href="https://forums.audiworld.com/a4b7/msgs/72013.phtml"> D@mn internet racers... </a>
Old Jan 14, 2007 | 06:37 AM
gtifrank69's Avatar
New Member
Default I have seen 5.8sec 0-60 and i just have Revo stageII.
My car is an 06 sixspeed Quattro. I have taken it to english town race way over the summer and have scored a 14.118 in the quater. If you have 275hp and your only getting sub 6.5 then your doing something wrong.
Old Jan 14, 2007 | 06:38 AM
gtifrank69's Avatar
New Member
Old Jan 14, 2007 | 05:23 PM
DukeLeto's Avatar
Default Re: Is it a tip car? I have seen sub 6 second times with just a chip but it was a 6-speed...
It's a manual, and it was on wet asphalt with winter tires, 4 degrees outside so it was a bit slippery. I assume that under proper conditions, and once I get to know the car in its new condition more, I could get 6 - 6.1
On the other hand Abt, Sportec and Nothelle all estimate 0-62 as being 6.3 seconds with their respective Stage 2 upgrades. Are they all half a second wrong? I assume they test them, or don't they?
I use 100 fuel.
wasco : the chip and the turbine come from Abt.
Audi2.0TFSI : For some odd reason, I could see that coming
Thanks all,
T.
Old Jan 14, 2007 | 08:58 PM
bhvrdr's Avatar
Default My guess is their numbers are a tad conservative just in case. I agree you should get to high...
fives with no problem. I pulled mid 5s to upper 5s with my chip only B7 with APR programming.
 Pouria Savadkouei
 Michael S. Palmer
the senator
9
Jul 20, 2005 11:17 AM
The Pope
Feb 24, 2003 11:09 AM
barrem23
Nov 5, 2002 08:23 PM
JazziTT
Dec 4, 2001 06:29 AM
Reese
Dec 11, 2000 05:04 PM
