Jerking Issue Update (kinda long)
So I first took it in to the dealer to have them look at it under warrenty. They couldn't even tell there was a "jerk" to begin with so they just told me to quit whining and go home haha (they didn't really say that in that exact words). But I still noticed it. So just to confirm that I wasn't insane I took a weekend, got the clutch off and disassembled it. I found that the throw-out bearing was either mounted improperly or became mounted improperly (probably what happened during the "bursts" of speed). It was engaging off on an angle. I'm guessing this probably made the pressure plate unable to disengage fully. At the same time if the throw-out bearing was to be disengaged, it probably did it improperly as well. I think this made the P plate unable to engage. I caught the problem really early so there was no damage (also since the angular discrepencies were still within accpetable tolerance). I corrected it and the problem went away! woo hoo! If anyone is having similar problem maybe look into this. I can't guarantee that your having the problem due to the same issue I've had but you never know.
I suppose its possible that the throwout bearing moved as a result of some abuse. But I can't say i have ever heard of this. Hope to hell this never happens to me. Awesome post and thanks for the info!
