A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
RNS-E retrofit question
Old Jan 19, 2007 | 08:13 PM
RickS's Avatar
Default RNS-E retrofit question
My RNS-E retrofit is great, but I can't get the nav info to display between the tach and speedo. I have vag coded with the proper code, pulled the fuses to the instrument cluster and radio, to no avail. Does anyone know what I need to try next?
Thanks,
Rick
Old Jan 19, 2007 | 08:21 PM
Bob@Stratmosphere's Avatar
Former Vendor
Recheck the vag codes again
Old Jan 20, 2007 | 04:11 AM
PetrolDave's Avatar
Default Wait ....
Provided you have the correct code in adaptation channel 62 of the instruments (most likely what was already there PLUS 4), then the best thing is to just wait.
Sometimes the CAN bus messages to the DIS don't get properly sent when you setup the new value, but if you wait (maybe a few hours, maybe a few days) it SHOULD start working OK.
Old Jan 20, 2007 | 07:59 AM
cpurick's Avatar
Default What were your before and after values in Ch.62?
Also, is your saved value still there when you reconnect the VAGCOM?
Old Jan 20, 2007 | 08:21 AM
RickS's Avatar
19 before, 23 after, they are still there
Old Jan 20, 2007 | 09:13 AM
cpurick's Avatar
Default Re: 19 before, 23 after, they are still there
Well, I see you've already been over to navplus.us.
You realize, of course, that even if you do this successfully the red DIS can be a little buggy in navigation, right?
Old Jan 21, 2007 | 10:20 AM
PR0XUS's Avatar
New Member
Default change value of ch 62 to 5 and you will be fine...
...sometimes ECU doesn't allow to run values greater than 19+ so if your instrument cluster default value was 16 and you add 1 for radio and 4 for nav...ECU will not accept it.
You can easy use lower values.
1 for radio and 4 for nav = 5
if you have phone system you can add another 2 (7 total)
EuroVWGTi
Feb 22, 2008 05:06 AM
cyclezib
VAG-COM Discussion
Jan 6, 2008 08:08 AM
iconoclast
NY / NJ / CT Discussion
Feb 26, 2007 06:18 AM
Mike B
Jan 20, 2006 07:29 AM
dynamo04
Nov 28, 2004 05:21 AM
