some a4 questions
questions:
1) how reliable is this engine with a chip? Have there been any turbo failures on engines with the APR chip? (this seems like the best choice from what i've read). is there a documented failure rate?
2)what kind of performance figures can I expect from a chipped car? (quarter mile? 0 - 60?)
3) how hard is it to find a fully-loaded titanium s-line avant in black? would i have to order this car, or is it possible to find on a dealer lot?
thanks
No idea on longevity yet, obviously, but the engine seems pretty solid. We have almost 25K miles on the A3 with no issues <knock on wood>.
I added a test pipe about a month ago and it opened the car up even more. While I have not been to the track with the pipe I would guess I should be able to run high 13's as others have posted similiar times.
FYI: I have a manual trany. If you do a search I believe there are some 1/4 mile times posted.
The S4 is a great car. I like my A4 but I think the only way to get comparable power to a S4 would be to run the K04 from what I have seen.
Good luck with your decision..
The disadvantage of going fromn S4 to 2.0 A4 is engine sound. The S4's SWEET sound just isn't there with the 2.0. :-(
To get a manual 2.0 Avant, I had to order, and I'd do it again. Well worth the wait.
I've seen reviews that label it as rough.
I like it better than the 1.8t. The 1.8t sounded
like a grunting fat pig.
The 2.0T makes these little ticking noises,
but that is OK. It almost sounds like a diesel.
And it just revs forevah. I end up driving mine
like a diesel. There is almost no reason ever
to go above 5000rpm
