Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Touchup paint very dark
Old Feb 26, 2009 | 02:20 PM
SouthernMdRan's Avatar
Default Touchup paint very dark
I picked up some meteor grey touchup paint from a dealer to fix a chip I picked up on the hood of my car. The paint of course consists of a paint "stick" and a clear coat "stick".
I have used the paint stick on the chip, and it is very dark...kind of a dark purple to almost black. It stands out terribly against the lighter paint (at the moment).
Am I doing anything wrong here? Will the color lighten as it dries? Anyone know how long I should let it dry before I apply the clear coat?
Looking for anyone who has used this color of touchup paint to let me know what their experience has been.
Thanks
Old Feb 26, 2009 | 02:49 PM
AofC_RR's Avatar
Did you shake the $h!t out of it first before you applied it? That's important.
Old Feb 26, 2009 | 03:12 PM
Default Re: Did you shake the $h!t out of it first before you applied it? That's important.
Well, I thought I had. I've shaken the tube a lot...and in fact 'tested' the paint on a benign surface (not on the car) several times and cannot see any significant change in the color despite additional shaking.
Just wondering if it lightens over time...or if the clear coat has any effect in terms of lightening...although I can't see how it would.
Old Feb 26, 2009 | 04:27 PM
Misplacedyankee's Avatar
Default You might have applied too much...
I use a toothpick to apply paint to a chip. Just a small amount is needed and it will spread itself. You may need to use a compound, polish and wax to get it blend right.
Old Feb 26, 2009 | 10:07 PM
bigk103's Avatar
Default How much $$$?
So I slightly hit a pole in my parking garage and should touch up the paint as well... Was just wondering how much the paint was from the dealership? Is it more for metallic paints i.e phantom black?
Old Feb 27, 2009 | 02:19 AM
Default Re: How much $$$?
It cost me about $17...which gets you a tube of paint (my color again was meteor grey pearl) along with a tube of clear coat.
Old Feb 27, 2009 | 05:56 AM
bb vign's Avatar
Default Can't help with your question but you should try Dr. ColorChip
as it really produces a great result. I've used it on a few chips on the S5 and the fix is practically invisible IMHO.<ul><li><a href="http://www.drcolorchip.com/">Dr. ColorChip</a></li></ul>
Old Feb 27, 2009 | 07:01 AM
IAS5's Avatar
Default would you buy it again?
I'm assuming you would, since, in a way, you are recommending it.
Is it as easy as it is described?
thanks
 Michael S. Palmer
Old Feb 27, 2009 | 10:48 AM
bb vign's Avatar
Default Absolutely! Super simple to use and works as advertised IMHO
Although for deep scratches you will need multiple applications.
scottndsky
Q5/SQ5 MKI (8R) Discussion
May 8, 2017 04:56 PM
MadMadS4
S4 (B8 Platform) Discussion
9
Jun 1, 2011 10:27 PM
KO4ed in Phoenix
Jun 25, 2004 10:26 AM
Regl
Jul 5, 2002 12:41 PM
