Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Gas Pedal Sticking Update...
Old Mar 5, 2009 | 05:52 PM
pudding's Avatar
Default Gas Pedal Sticking Update...
So I figured out why my pedal stuck. Happened the hard way, thankfully on a road where there wasn't anyone or any car. I was accelerating and the pedal of course became stuck. It was floored even though I didn't do it. Happened to be my mat. I am going to try to find new ones and better ones. Here is my question though...
I popped it into neutral to stop again and it kept revving while in neutral. From my shifter there was this noise, not sure what it was. Sorta sounded like when you try to shift and you don't put it all the way into gear, grinding gears. It happened so fast though, I don't think it was that. I had no burning clutch smell either. Had my foot on the clutch and turned off the engine, turned on a light stepped out and found my problem. But, my clutch felt softer after all this once i turned my car back on and started to drive again. (Luckily 2 blocks from house). Could it all haven been in my head with my clutch? Are there any ways to check how worn my clutch may be? I accelerated through the gears to check for slippage, non found. Anything else I can do to check it. Any suggestions?
I will pull my mat back from now on until I get new ones.
(BTW, I only have 1200 miles, so it shouldn't slip or be bad. Just as this is my first manual car I guess I am a little over concerned).
Old Mar 5, 2009 | 07:19 PM
antiSUV's Avatar
Default You don't need new mats. Just need to make sure the mats are secure.
OEM Audi mats still the best, IMO. Have used both the stock carpet and rubber Audisport mats in my two Audis (B5 and B7), and they have worked quite well. The key is to make sure they are secured to the two posts, not just one.
Have experienced the sticking pedal problem in my Saab due to mats sliding up and wedging under the pedals. Need to get retainer posts for the car at the next service. My car wash guy seems to break them off quite easily.
Old Mar 5, 2009 | 07:26 PM
pudding's Avatar
Default How do I secure them to the posts? Do they click in sorta like I guess you could say a button?
And anyone have any info on the clutch?
Old Mar 5, 2009 | 08:22 PM
EGainer's Avatar
Default ok so it was the mats?
just make sure they are locked into the floor posts
only people who don't lock mine in are the guys who clean my car.
i click them back in every time they come out
Old Mar 5, 2009 | 08:27 PM
MARKNMTT's Avatar
Default Yes they just click on...every Audi you MUST do this. I've had it slip up a few times in various
Audis when the car wash guys don't do it and i didn't pay attention and sure enough...zooooom. Fortunately i know exactly what it is when it happens and just yank the mat back with my heal or reach down and grab it quickly.
Old Mar 5, 2009 | 09:39 PM
1.8TQ99.5's Avatar
25 Year Member
Uh-oh, don't tell 60 Minutes about this...
Old Mar 6, 2009 | 01:46 AM
Autofahrer's Avatar
Default Re: Gas Pedal Sticking Update...
Pudding,
don't worry about your clutch. It will take no damage when you disengage while revs are high.
It only will take damage when you do it the other way around.
Sometimes you see/hear elderly people do this. They rev up to 5000 or so rpm and then engage 1st gear and let the clutch slowly engage, over and over again. This is when you can smell some material burning...
Again, you don't need to worry about your clutch at all with this one.
To check for slippage, you do not accelerate through the gears.
At stand still, you select 3rd gear, rev the engine slightly higher than normal when you usually start to drive and then let the clutch engage very quickly. If the clutch is o.k., your car will jump forward for maybe a foot or so but then come to a standstill.
If the clutch has slippage, the car would keep on driving.
A clutch is good for usually way more than a 100k miles.
Only if grandpa has it for a few weeks, engaging at 7000 rpm every time, it will affect its duration....
Old Mar 6, 2009 | 07:06 AM
Jay 4R's Avatar
it lurched...
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 6, 2009 | 12:27 PM
1.8TQ99.5's Avatar
25 Year Member
run for the hills!!
BretKeleher
Nov 5, 2013 07:32 PM
Mx-3GSR
Audi allroad
Jan 19, 2009 10:32 PM
Mike Desi
Quattro: Turbo / Ur / Sport
May 27, 2007 05:21 PM
Octane
Apr 25, 2003 10:55 AM
