Paging Chuck, want to talk about the widebody
Old Mar 14, 2009 | 10:59 PM
silverA4TQM's Avatar
Junior Member
Default Paging Chuck, want to talk about the widebody
just starting getting my widebody going and wanted to see if I could check out some of your work and tools and all some day soon? TIA
Nigel (no more S4)'s Avatar
Default sucker.
seriously
Old Mar 15, 2009 | 09:57 AM
NeverSummerS4's Avatar
Alex is that you?
Old Mar 15, 2009 | 06:25 PM
GollyGwagen (Chuck)'s Avatar
Default Sure thing, but I would seriously consider having a pro rough in the qtrs!
The rest is pretty easy and straight forward, but those are a bear! I wouldn't recomend what I'm doing to anyone!
Old Mar 16, 2009 | 05:51 AM
Default I was replying from my phone, but here's why in a little more detail
If you don't get it right the first time, you will have thrown a great deal of money out the window. You can still save a lot but having SVE rough them in (no body work, no paint, nada) and then take over from there. The rest is very straight forward except the rear bumper. But if you blow that you can always bolt on a different one!
If you decide to do it yourself, there are three basic things I believe you need. A flanging tool, some good heat isolating putty, and experience with a welder. Weld scrap sheet metal together for practice until you get a good penetrating weld and it doesn't warp at all. Make a template to check your warpage and then use that setting when you weld. Also, use sheet metal screws to get everything in place and lined up right. Easy to undo/move/tweak the parts that way.
I'm sure it could be done in fairly short order, I'm just so busy I havn't had time to work on my car. Just remember, I'm going on 1-1/2 years so don't be in too big of a hurry!
daves4izzle::ASP 3-
15
Mar 26, 2008 12:56 PM
Roger @ CA
Mid Atlantic Discussion
Mar 18, 2008 11:41 PM
Boston Driver
Oct 15, 2007 08:34 AM
M1LL10N
Dec 5, 2005 09:57 PM
MDIAU
Nov 26, 2005 01:11 PM
