1995 S6 keeps failing emissions ?
Has had plugs replaced and O sensor replaced, actually made the test results worse.
No error codes, and drives well.
What to do ? Are there any local shops that can test emissions and make it pass the emissions test ?
Already tried the can of 44G - failed first emissions test after this.
Checked for exhaust leaks - no observable problems.
The local shops in Denver (Avalon, 303, etc) and SCR in Loveland might be able to help.
Maybe try a un-chipped ecu...retest after retest does get old......
I took it to my exhaust guy, he actually checked the cats by drilling in to them (if they
are not bad, he just welds up the hole)... the right side cat was half gone
and the left was on its way. I had them replaced ($500) then drove the car
up and down the interstate at high speeds then went and got it
tested.... amazing how much the numbers came down, on all measures!
