new wheel cleaner. maybe worth the try...
Old Mar 16, 2009 | 06:19 AM
2PUTT's Avatar
Default new wheel cleaner. maybe worth the try...
its that time again.<ul><li><a href="http://www.audizine.com/forum/showthread.php?t=270868">wheels</a></li></ul>
Old Mar 16, 2009 | 06:23 AM
WECoyote-SuperGenius's Avatar
Default The only time that I've needed anything stronger than car wash soap for washing the wheels .....
is cleaning up after a busted c/v joint boot. What am I doing wrong?
Old Mar 16, 2009 | 06:31 AM
mktbully's Avatar
How is this compared to P21S gel?
Old Mar 16, 2009 | 06:39 AM
brianja's Avatar
Default I don't think anyone has tried it yet (maybe Phil from DD has).
I like P21s gel enough that I likely won't change (especially since I have a fresh 5L bottle of it waiting to go).
I'm expecting a shipment of Tardis (VERY tough to get tar/adhesive remover) this week so I should be all covered for wheel cleaning for the summer.
Old Mar 16, 2009 | 06:42 AM
mktbully's Avatar
hmmm Phil pls chime in. i'm running low on P21S and if this is as good or better i'll try it
Old Mar 16, 2009 | 07:12 AM
JimmyC83's Avatar
Default His reply to my OP on AZ
<ul><li><a href="http://www.audizine.com/forum/showpost.php?p=3496331&amp;postcount=4">http://www.audizine.com/forum/showpost.php?p=3496331&amp;postcount=4</a</li></ul>
Old Mar 16, 2009 | 07:22 AM
2PUTT's Avatar
i use carwash soap as well.
Old Mar 16, 2009 | 08:16 AM
Mr. Mom's Avatar
AudiWorld Expert
Default if that floats your boat....
wait till you track the car...
track pads do a number on the finish
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 16, 2009 | 08:30 AM
2PUTT's Avatar
good thing i have track wheels all set. =)
Old Mar 16, 2009 | 08:44 AM
Mr. Mom's Avatar
AudiWorld Expert
Default if having clean wheels is an issue, you made the correct call
especially if you ever track the car in the wet......
gridgirl
Wheels & Tires Discussion
Feb 17, 2011 08:07 AM
lapper
16
Aug 27, 2008 09:25 PM
Skrill (RexxKw0nDo)
Motorsport Discussion
Apr 3, 2006 05:18 AM
Aldous
24
Jan 2, 2003 04:39 PM
got_root?
Mar 3, 2002 09:30 AM
