track junkies.... whats the best place >
Old Mar 24, 2009 | 09:08 AM
TTwizted13StrtRcr's Avatar
Member
Default track junkies.... whats the best place >
to source some lower control arms? whats the best out there as of now?
im entering a rally later this year, want to finish building my suspension by then.
also any suggestions for camber plates?
Old Mar 24, 2009 | 09:48 AM
J. Patterson's Avatar
I would go here, if you mean rear. I am not aware of any front available.
http://www.gocpt.com/products/1/controlarms.php
Old Mar 24, 2009 | 10:40 AM
Member
it says i need 2 sets to adjust the toe (that would be both upper and lower control arms).... isn't toe adjusted by the lower control arm though?
Old Mar 24, 2009 | 10:44 AM
GOFASTT's Avatar
second on CPT... you'll only need to replace the lower set. For camber plates "Ground Control" is the way to go.
Old Mar 24, 2009 | 11:01 AM
When you change camber with the lower, that changes toe too. The trailing arm mount is mounted in slotted holes and can be moved to adjust toe there but it is a bit clumsey. If you use that you would put the adjustable arm at the top, as it will change toe less there as you adjust camber. Both upper and lower would allow you to do everything with the CPT adjustables.
JohnLZ7W
14
Mar 19, 2008 07:46 PM
galkokolaf
Mar 18, 2008 01:01 PM
DasTT
11
Jan 10, 2006 02:57 PM
OldSchool AG
Jan 17, 2005 01:56 PM
mrcj7
Feb 23, 2003 04:12 PM
