opening glove compartment -lever broken off
Old Mar 28, 2009 | 12:52 PM
zenmasTTa's Avatar
Member
Default opening glove compartment -lever broken off
Hey-
just wondering if anybody had any ideas how to open the glove compartment when the lever has been broken off (I didn't do it :-) ) I can't seem to make sense of the mechanism yet... -I will post pics if that will help.
thanks!
Nicholas
Old Mar 28, 2009 | 03:52 PM
zenmasTTa's Avatar
Member
Default no wisdom yet? :-)
anybody?
Old Mar 28, 2009 | 09:10 PM
hahnmgh63's Avatar
Should be able to just push your finger in the whole with one hand while pulling the glovebox door open with the other.
Old Mar 29, 2009 | 06:33 AM
GeTT da NeTT's Avatar
Depends on what cause the handle to break. Put a common tip screwdrive into the slot and push toward the passenger door. It should open.
If it doesn't, then you have to take the cover off the side, then remove the locating assembly (3 or 4 screws) and you cansee the pin that is holding the door up. Push that in with a small phillips screw driver and work the latch at the same time. Door opens.
Old Mar 29, 2009 | 07:52 PM
zenmasTTa's Avatar
Member
thanks Gett da Nett- that did just the trick!
Now if I'm pulled over by the cops, I can't use the "my glovebox handle is broken so I can't get my registration" excuse :-)
It seems like the pins at each end are bit sticky so it takes a little bit of fiddling to get it open each time... I wonder if there is a fix for that?
Old Mar 29, 2009 | 08:00 PM
nimbusgrey's Avatar
New Member
http://www.audittcca.com/pdf/audi_tt...box_repair.pdf
Old Apr 4, 2009 | 02:45 PM
zenmasTTa's Avatar
Member
Default thanks nimbus! that looks like it might be useful in repairing my glovebox!
I don't really want to spend too much $$ just because one nub is broken...
TFT
Sep 21, 2018 06:52 PM
hubturn
Jul 31, 2009 01:02 PM
DBenn (Derek)
Sep 15, 2005 08:18 PM
speedracerrc
Audi 100 / A6 (C4 Platform)
Jul 27, 2003 08:15 PM
meem
Nov 10, 2002 10:34 AM
