Lateral Acceleration Sensor (G200)
I can't find this part at worldimpex or elsewhere. Can someone point me to the correct place?
Do I understand correctly that I will need to "zero" the sensor after I install it, using the full version of VAG-COM?
Thanks.
Does anyone have instructions as to how to "zero" the sensor?
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 D
Component: ESP 20 CAN V006
Coding: 23049
Shop #: WSC 01236
VCID: 3D6FECD93778C8F00AA
1 Fault Found:
01423 - Lateral Acceleration Sensor (G200)
57-00 - Electric Circuit Failure
Thanks in advance for any help...
Thanks.
Coding: 23049
Shop #: WSC 01236
1 Fault Found:
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 2, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
[Coding-II - 11]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 063
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
To make sure the basic setting was succesful, check the sensor again.
Group 004
[Go!]
[Done, Go Back]
[Close Controller, Go Back - 06]
