2000 A6 2.7T headlights wandering....
There is a suspension deflection sensor attached to the front and rear suspension. I believe they are on the driver's side and are fairly easily accessible although the fault would have most likely been there before you changed the lights as they should be compatable.
There may be some calibration they need, possibly via VAG-COM?
While these things DID run through the range motion quickly when the sensor malfunctioned, it doesn't anymore after fixing, which is strange. Now I only see it make minute adjustments when I lightem up.
The only way a fully dynamic system could be produced is if it were to utilise some type of reflective system to deflect the beam - such as used in a DLP projector, but used to deflect the light rather than refract it. You would also need some form of laser or monitoring to detect the road surface just in front of each wheel - probably a bit over the top really I suppose?
Thanks again, fellas!
