ok bout to give up...how do i get the rear bumper off???
Old Mar 31, 2009 | 08:54 PM
WOWDee's Avatar
Default ok bout to give up...how do i get the rear bumper off???
Trying to install a trailer hitch .... I have removed every freakin nut and bolt I can think of following the bently manual but I still can't get the rear bumper cover or assembly off ...what gives? I tried using the search function but quickly gave up on that. Is there some kind of hidden clip or something besides the 2 flange nuts under the tail light, 3 fender flange nuts, 2 wheel well bolts, and 2 bumper shock bolts on each side ..... oh and the lower cover center torx screw ....... I can't believe these instructions are so poorly written ..... the bumper won't budge so I beginning to believe there has to be some other fastener that I have missed that is not called out in the manual or is somehow very obscure. Thanks in advance!!!
Old Mar 31, 2009 | 09:34 PM
WOWDee's Avatar
Default Nevermind-Found the write up-Missed 3rd(torx)screw in wheel well-duh!
Nice write up by the way!!!!!
https://www.audiworld.com/forums/sho...php?p=15167709
Old Apr 1, 2009 | 12:10 AM
WOWDee's Avatar
Default Well apparently no 3rd screw in wheel well ... it was the clips holding.....
the bumper to the fender ........ the spatula trick worked well ..... but now my flap jacks are going to have a European taste to them. ahahaha!!!
Old Apr 1, 2009 | 06:36 AM
Boston Driver's Avatar
AudiWorld Expert
You should get a Bentley Manual, since it appears that you like to take things apart.
Old Apr 1, 2009 | 11:02 AM
WOWDee's Avatar
Default That's what I was using (and NO I NO LIKE!!!) I now have a hitch! :) >>>>
The bentley process was somewhat simplistic and not quite clear ...... the process I attached was pretty good .... KUDOS TO THE AUTHOR ... the spatula idea to disengage the clips from the fender was the trick i needed ...... or maybe it was a few more curse words and grunting ....who knows???? ANYWAY I NOW HAVE A HITCH ..............WOOOOOOHOOOOOOOOOOOO!!!!
Old Apr 1, 2009 | 08:20 PM
JLaws's Avatar
Tow with a 2 point slow? Avoid hills :P
Ragdoll
Apr 17, 2009 10:35 AM
AUDIMAN3
Audi 100 / A6 (C4 Platform)
Oct 3, 2008 03:13 PM
quattros.org
Apr 21, 2008 09:24 AM
SteveAngry
Mar 20, 2003 04:35 AM
bcacly
Feb 14, 2003 07:16 AM
